EG rear hatch
EG rear hatch
Does anyone know where to get the plastic plugs to put into the rear hatch when you don't have the struts anymore? I've been trying to find them online, but don't know the part number or if it's something you can get from Honda.
Re: EG rear hatch (DCivic00)
After finding another picture, I may have realized that it might be one of the pieces that holds the strut in place. Either #21, 22 and 23. Is this correct?
Re: (DCivic00)
ok now i know what u are saying and it will not work.u will need the rear strusts to hold the lower glass nut and seal in its place.cause there is a bolt on the rear strat (lower side that mounts on the glass) that goes on the number 21 which is a screw.cause i have just replaced the struts and all the rubber seals and screws.costs me about $100
Re: (crazyguy)
Well what I was planning on doing is taking out the rear strut. I've seen on other peoples hatches that don't have the glass strut, but only have a piece of plastic that fits in the holes on both sides. That's what I'm looking for.
Re: (DCivic00)
oh.in that case i have no idea,but a piece of advise.if u mess around with that 2 lower seals on the rear window.it will leak.once u park your car outside and it rains.your cargo area will be soaked.cause those 2 metal screws hold 2 weather seals.just a friendly reminder cause my hatch was leaking thats why i replaced all the seals.include the rear wiper seals.
Re: (crazyguy)
the only time I've seen no rear struts on the rear window like that, they put in two shorter 8mm bolts and a couple washers to hold the normal buttons in place.
just in case you still want them.
#21 - 90101-SR3-000 - nut, opener stay piviot (lower)(8mm)
#22 - 90105-SR3-000 - seal, tailgate opener stay & Wiper motor
#23 - 90106-SR3-000 - spacer, tailgate opener stay
if you just want some plastic plugs for the hole i bet they have some at your local hardware store just measure the size of the hole the ask for plastic end caps in that size
bambbrose
02-16-2010 10:04 PM
e-eg6
09-30-2008 10:34 AM
F120man
12-19-2002 05:20 AM
21, 90101sr3000, 90105sr3000, 90106sr3, 90106sr3000, buy, civic, del, hatch, honda, rear, sale, seals, sol, window
