need help...
Old Aug 15, 2007 | 06:41 AM
ceyazzie's Avatar
Default need help...
i took off the head on my sohc vtec... the block-TDC.. i hope the head was too. i got the head resurface, cleaned up, and new seals... due too a blown head gasket. but i got the head back and not on TDC.. how do i make the head go back to TDC with the block and what i need to know before putting the head back on and starting the car??? this is my first time.... need help plzz.
Old Aug 15, 2007 | 06:51 AM
ham's Avatar
ham
Default Re: need help... (ceyazzie)
the cam gear has marks on it to indicate the TDC position for reintalling the head
also, you will have to readjust the valves once you get it back together.
Old Aug 15, 2007 | 06:58 AM
ceyazzie's Avatar
Default Re: need help... (ham)
i think the valves r adjusted.. i think but not sure.. how do i know??
Old Aug 15, 2007 | 06:59 AM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceyazzie &raquo;</TD></TR><TR><TD CLASS="quote">i think the valves r adjusted.. i think but not sure.. how do i know?? </TD></TR></TABLE>
Pull off your Valve cover and gauge them. it takes like 15 minutes.
Old Aug 15, 2007 | 07:03 AM
ham's Avatar
ham
they arent...
the cam was removed so they need to be at least checked and the head has to be torqued to the block and the timing belt on.
Old Aug 15, 2007 | 07:09 AM
ceyazzie's Avatar
how i loosen the cam to turn to TDC??
Old Aug 15, 2007 | 08:37 AM
ham's Avatar
ham
dont loosen it, just spin it with the cam gear on
si0385.
Feb 13, 2006 07:40 PM
Brien
Dec 9, 2005 04:58 AM
^AnDre^
Dec 1, 2004 10:51 AM
JMinSi2000
Aug 16, 2004 08:11 PM
