92 Civic CX Timing Issue
Old Aug 15, 2007 | 05:35 AM
TaSe's Avatar
Default 92 Civic CX Timing Issue
Hi all, a friend of mine had a bad distributor on her car and it was changed out (reman one) but now she has a very rough idle that jerks the car and she is upset that this is happening. Where are the marks to tell me if the timing is dead on or off????? I looked but couldn't find it. Another thing how can i set the timing? Do i disconnect the distributor and turn it with my hand or should i take it out and put the #1 spark plug back to TDC and try from there?
Modified by TaSe at 6:52 AM 8/15/2007
Old Aug 15, 2007 | 05:52 AM
speedooo's Avatar
Default Re: 92 Civic CX Timing Issue (TaSe)
you just loosen it and adjust it
Old Aug 15, 2007 | 06:08 AM
TaSe's Avatar
Default Re: 92 Civic CX Timing Issue (speedooo)
Thanks,
Do you know where the timing marks are? This car does not have a Tach so its hard to hear it.
Old Aug 15, 2007 | 06:58 AM
ham's Avatar
ham
you should use a timing light.
Old Aug 15, 2007 | 07:20 AM
TaSe's Avatar
Default Re: 92 Civic CX Timing Issue (ham)
I have a timing light but i need to know where the markings are so i can see what hte timing is.
Old Aug 15, 2007 | 07:53 AM
Ron454321's Avatar
On the timing belt cover there are 2 marks, you look at the first one it looks like a w coming out of it, the second one looks like a v. This is where you willpoint the light, the marks should show up on the crank pulley if you have everything set up right.
Old Aug 15, 2007 | 08:10 AM
TaSe's Avatar
Default Re: (Ron454321)
THANKS!
miksew
Jun 7, 2006 08:03 AM
DieMaster
Jul 2, 2004 09:09 AM
ScottEK
Nov 2, 2002 01:15 PM
Tx92AccordExD
Jul 22, 2002 11:13 PM
yakkosmurf
Dec 24, 2001 08:08 AM
