Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Changing oil in 2002 manual transmission
Old Aug 15, 2007 | 03:48 AM
boomerbrian's Avatar
Default Changing oil in 2002 manual transmission
How do I change the tranny oil in my 2002 civic lx sedan with manual tranny?
Also the same question for my wife's 2000 civic sedan but automatic tranny.
And yes, I want to do it myself.
I've new to this group so be gentle.
Old Aug 15, 2007 | 04:40 AM
thinknology's Avatar
Default Re: Changing oil in 2002 manual transmission (boomerbrian)
I know I saw a write up on this somewhere... try the search feature, it's your friend
It should be put in the DIY FAQ though... whatcha think Matt? anybody seen a write up for this... I think it would fit right along with the engine oil change
Modified by thinknology at 12:21 PM 8/15/2007
Old Aug 15, 2007 | 07:46 AM
Default Re: Changing oil in 2002 manual transmission (thinknology)
Thanks!
Old Aug 15, 2007 | 01:51 PM
CrazycakesEM2's Avatar
It says how to do it in your owners manual, I belive. Other wise get down there and find the lowest bolt that doesn't connect the transaxle to the engine, this should be the drain bolt, then there is a large bolt slightly above this which is the fill bolt. Get 2 quarts for the manual and a funnel with a long hose attached. Fill until it starts running out.
Old Aug 15, 2007 | 01:52 PM
HONDURA2K2's Avatar
there is a drain plug at the bottom of the tranny, drain all of the fluid and put the plug back on. then you will see a plug further up on the tranny, that is the fill hole, keep filling until fluid starts to come out. should be about 3 liters
EDIT: you beat me to it
Old Aug 15, 2007 | 02:13 PM
oddmut's Avatar
Default Re: (HONDURA2K2)
hehe what's the oil for in the tranny? is it for the same reason the oil is in the engine? Also this is different from the sqeaking clutch right?
Old Aug 15, 2007 | 04:15 PM
i-VTEC_DOHC's Avatar
so the manual trans have a drain bolt??? hmm i remember someone sayin that the tranny gotta come off... but i doubt that
Default Re: (oddmut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut &raquo;</TD></TR><TR><TD CLASS="quote">hehe what's the oil for in the tranny? is it for the same reason the oil is in the engine? Also this is different from the sqeaking clutch right?</TD></TR></TABLE>
pretty much yes.
Old Aug 15, 2007 | 05:54 PM
petty$rep's Avatar
Default Re: (i-VTEC_DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">so the manual trans have a drain bolt??? hmm i remember someone sayin that the tranny gotta come off... but i doubt that</TD></TR></TABLE>
hahaha.....don't ever listen to the person who told you that.
Old Aug 15, 2007 | 09:56 PM
oddmut's Avatar
thanks bro.
Old Aug 16, 2007 | 12:29 AM
Default Re: (petty$rep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petty$rep &raquo;</TD></TR><TR><TD CLASS="quote">
hahaha.....don't ever listen to the person who told you that.</TD></TR></TABLE>
yea i was really doubting it... im gonna jack up my car tomorrow and look for the drain and fill bolt..
Old Aug 16, 2007 | 03:35 AM
It's a pretty simple procedure, and when this was posted my mind went completely blank but as always H-T comes to the rescue... but remember lower your car back down when you fill it, always want to fill fluids when you car is level
Old Aug 16, 2007 | 03:39 AM
toyomatt84's Avatar
Sanji
Default Re: (thinknology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology &raquo;</TD></TR><TR><TD CLASS="quote">It's a pretty simple procedure, and when this was posted my mind went completely blank but as always H-T comes to the rescue... but remember lower your car back down when you fill it, always want to fill fluids when you car is level </TD></TR></TABLE>
I'll see what I can do about mocking up a tutorial for the D17. I was thinking I could show how to do it, rather simply. But, then I was like, yeah how could I help.
Luckily enough, I know a couple people in my local area that still have theirs, so all hope is not lost.
Old Aug 16, 2007 | 03:44 AM
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
Luckily enough, I know a couple people in my local area that still have theirs, so all hope is not lost. </TD></TR></TABLE>
Lol I forgot about that haha... no I think it might be a little confusing if you took pictures of yours
Old Aug 16, 2007 | 04:49 AM
toyomatt84's Avatar
Sanji
Lol I forgot about that haha... no I think it might be a little confusing if you took pictures of yours </TD></TR></TABLE>
Yeah, hopefully either my sister or AJ will want to do theirs.
Old Aug 16, 2007 | 04:51 AM
Sounds good
I should do one... mine could probably use it I'm sure
Old Aug 16, 2007 | 07:06 AM
I got it figured out. Thanks folks!
Old Aug 16, 2007 | 08:29 AM
Tadehi's Avatar
Schumacher '10 WDC
I can do a write-up in 1300 miles.
Old Aug 16, 2007 | 11:03 AM
oddmut's Avatar
Default Re: Changing oil in 2002 manual transmission (Tadehi)
how often do you change the manual transmission oil?
Old Aug 16, 2007 | 11:24 AM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: Changing oil in 2002 manual transmission (oddmut)
Manual says 60,000 miles I believe, But I think I am going to change mine every 15-20,000 miles, just to help the poor sychros.
Old Aug 16, 2007 | 12:40 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tadehi &raquo;</TD></TR><TR><TD CLASS="quote">Manual says 60,000 miles I believe, But I think I am going to change mine every 15-20,000 miles, just to help the poor sychros. </TD></TR></TABLE>
Transmission fluid change every 30,000 miles with a transmission flush every 90,000 miles, for a Manual transmission.
Old Aug 16, 2007 | 12:56 PM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: Changing oil in 2002 manual transmission (toyomatt84)
Transmission fluid change every 30,000 miles with a transmission flush every 90,000 miles, for a Manual transmission.</TD></TR></TABLE>
Thanks for the correction
Old Aug 16, 2007 | 06:20 PM
petty$rep's Avatar
...so, now that you got your K, your to good for us D17 folks
Old Aug 16, 2007 | 08:20 PM
toyomatt84's Avatar
Sanji
Default Re: Changing oil in 2002 manual transmission (petty$rep)
Well, yeah? Just kidding, I'm still interested in helping the D17 chaps and ladies, simply because there's a lot to learn about the engine.
Old Mar 27, 2008 | 06:29 AM
K24_Y61P's Avatar
Yeah, hopefully either my sister or AJ will want to do theirs. </TD></TR></TABLE>
I'm ready Matt! Let's make a DIY.
