Help with ecu code 16~
Ok my ecu blinks 16 times...and i looked it up and it says check the fuel injectors...what should i do??(i know i have to do something to the fuel injecters) i have no idea some please help
[Modified by xxkenyon419xx, 1:17 AM 6/14/2002]
you may have a bad distributor that is what was wrong with mine. the only way to make sure is get a test light and turn the ignition on and test your injector wires. if you have a hot side and no ground side it is because you distributor is messed up. if no hot side it is the resistor box.
i dont have a resistor pack. its a 94 integra. I dont have any power to the injectors. I didnt check the ground on them. I will switch out the distributor tomorrow. Thanks. for the info.
That code is usually associated with a bad Main Relay...
Do you hear a clicking sound after turning the key on?
Take a peice of hose, long enough for you to set in the car. Stick one end in the filler tube of the tank, the other against your ear. See if you can hear the pump turn on, after turing the key to the start position...
