Possible short? Maybe?
Old Aug 14, 2007 | 09:24 PM
civicgeek133's Avatar
Default Possible short? Maybe?
Ok so last night as I was driving my car I was making a U turn. While I was turning the passensger side headlight and corner light went off and the rear passenger side turn signal stayed on. With the headlights off or JUST the corner lights on it acts perfectly fine. When turn the headlights on, the passenger side turn signal indicator on the cluster stays on along with the high beam indicator but is slighty dim.
I checked all the bulbs and wiring, everything seems to be fine. I haven't the slightest clue what the problem could be. I would appreciate if someone could chime in. If this helps the car is a 91' hatch with a B16.
TIA
Old Aug 15, 2007 | 10:01 AM
h2bv8killa's Avatar
76.106.76.207
Default Re: Possible short? Maybe? (civicgeek133)
sounds like it could be something with the actual turn signal lever which operates the high beams as well.
superfly23
Honda CR-V & Element
Feb 22, 2016 01:00 PM
jdm_ek_noob
12
Dec 22, 2014 09:09 PM
jerzytatt00
Lighting
Jun 26, 2011 01:48 AM
Garfield
Lighting
Jan 26, 2008 04:32 AM
civicgeek133
Aug 15, 2007 06:04 AM
