what master cylinder should i use on my eg?
Old Aug 14, 2007 | 06:43 PM
important's Avatar
Default what master cylinder should i use on my eg?
I would like to upgrade my master cylinder due to mine going bad.My quesiton is which one should i go with,i was thinking a early model prelude but throw an idea at me.Should i just go with stock?
Old Aug 14, 2007 | 06:54 PM
hondamark35's Avatar
Default Re: what master cylinder should i use on my eg? (important)
unless you have already upgraded the rest of your brake system i.e. rear disc conversion, you should just use the stock replacement.
i am not really sure you can just pick any MC and hope it fits. the upgrade would be the larger bore MC that, i think comes in the GSR or ex 4dr. you would also want to get a diff proportioning valve.
what it all boils down to is that better tires will give you better stoping power over a slight MC upgrade, (with the exception that you are road racing this car and you have the best tires and rotors and calipers you can put on it)
Old Aug 14, 2007 | 07:36 PM
BlueIntegraBoy's Avatar
Just get a stock replacement. No need to upgrade unless you upgrade your brakes.
Old Aug 16, 2007 | 03:26 PM
important's Avatar
it will have rear disk and ls knuckle assembly along with brakes.But i just put a stock one on from advance auto.
Brock Brum
11
Oct 25, 2017 09:36 AM
5.0 Killa
Suspension & Brakes
Oct 29, 2009 10:40 AM
anth2k4
Suspension & Brakes
Apr 26, 2007 10:55 AM
DEIVIONCRX
Feb 10, 2006 10:21 PM
jarvis199
Apr 29, 2005 12:57 PM
