2000 EBP CIVIC SI 6kkkkkkkkkkkk
6k located in suffolk
it will come with everythign 100% stock
only thing it will have is eibach springs
needs dizzy timing adjusted
the dizzy makes a noise and someone told me it needs a bearing
needs drivers side and rear motor mount
and the front end is a lighter blue than the rest of the car but the hood matches
needs axle seals cause the tranny fluid leaks deom them and needs oil pan gasket but i have bout all that stuff and i will give it to the buyer with the car.
i found another car and need this gone and you cant find a si for 6k with a jdm b16 and jdm gsr tranny for this cheap
94k on chassis
idk how much on the motor
NO TRADES!!!
car doesnt need to be driven a long distance untill stuff is fixed but is still driveable just not recomended cause the tranny fluid leaks from axle seals and hit the ehxaust causing it to burn off and make smoke and smell bad lol
DOESSS NOTTTTTTTTTT COME WITH TYPE R SEATS..comes with ls seats
the wratchet strap is to keep the motor from moving cause of broken mount rubber
94k on chassis
NO TRADES!!!
92-LS-Civic
18
Aug 20, 2005 12:09 PM
