integra whistling???
Old Aug 14, 2007 | 06:25 PM
itslikethis's Avatar
Default integra whistling???
when my car is running, there's a noticible 'whistle' coming from either the engine compartment or the interior or the vehicle. i cannot pinpoint the sound beings its such a high pitched noice. idk, maybe im deaf, but i know theres a whistle. what can this be? i was hinted it may be a fuel pump on the way out but this is definately a first in that i've never heard of this problem before. any help would be appreciated. thanks
Old Aug 14, 2007 | 06:27 PM
italianchooch88's Avatar
do you have a aftermarket intake?aftermarket filter>?
Old Aug 14, 2007 | 08:25 PM
sdinteg's Avatar
Default Re: integra whistling??? (frostie1)
does it whistle more at certain RPM's/speeds/throttle positions? Or when your radio is on? It could be a lot of things - intake, throttle body, audio amp ground loop noise, mouse under your seats, etc. either the engine compartment or interior gives us too many variables.
Old Aug 14, 2007 | 08:36 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: integra whistling??? (sdinteg)
Ha mouse under the seats, I first thought of it being your intake, if you have one...
sdinteg made a good point...
Old Aug 14, 2007 | 09:42 PM
haha...no, the car is 100% stock. ummm, i really cant tell if the whistle fluctuates at different rpm's, its most loud at idle probably because thats when i can hear more clearly
Old Aug 14, 2007 | 10:14 PM
gsrob's Avatar
Default Re: (frostie1)
Is it when you AC is on? If so, just about every integra that I have heard while running the AC, including mine, has a pretty distinctive whirr/whistle.
Old Aug 14, 2007 | 10:53 PM
N2O INTEGRA's Avatar
you need to use resistor type spark plugs on your car if you went cheap it will come through the speakers even when the stereo is turned off
Old Aug 14, 2007 | 11:24 PM
__oversea's Avatar
Default Re: integra whistling??? (N2O INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">you need to use resistor type spark plugs on your car if you went cheap it will come through the speakers even when the stereo is turned off</TD></TR></TABLE>
wtf??
have you checked all the hoses? vac hose.
could be P/S pump?
try to locate the sound
Old Aug 15, 2007 | 06:20 PM
will do...thanks everyone
Old Aug 15, 2007 | 06:33 PM
SlammedDC2's Avatar
Semper Fidelis
Old Aug 16, 2007 | 10:59 AM
B18CivicHatch's Avatar
have you checked the pcv valve lately i have a 98 ls in my civic and i noticed a whistle coming from my pcv valve i replaced it for like 3 bucks and havent heard it since
Old Aug 16, 2007 | 02:36 PM
vtec8804's Avatar
* B A N N E D *
b4 my dizzy went it sounded like there was a family of chipmunks under my hood... i told ppl it was my bov chirping
almostjdmeg
Nov 13, 2019 12:12 PM
ix3mydc
Jul 31, 2009 11:33 AM
rsf-g
Oct 2, 2007 05:42 PM
accord0494
Apr 12, 2005 12:04 PM
