how hot should an AC condensor get???
I noticed that my engine runs hotter with the AC on so I did a quick test.
I placed my hand on my AC condensor while the AC was on, and it was very hot, I can only hold it for a few seconds.
Then, I turned the AC off and INSTANTLY the condensor cooled down greatly, within a few seconds.
I turned the AC back on and the condensor went immediately back to HOT HOT HOT. Within a few seconds, it was already HOT to the touch again.
Is this normal?? A few years ago, I punctured the condensor in Baja and all the freon leaked out. I had the condensor replaced with a new one, and AC recharged, ever since then, it's had a small leak. My mechanic just adds a can of freon to my system whenever it stops cooling (once a year or so, last did it a month ago)
Sounds like air in the system. When the compressor mashes down air, it heats, just like a turbo. You're leak needs to be found and fixed. And draw the A/C system down with a vac pump to eliminate contaminants.
Either that or you have real shitty airflow thru the radiator/condenser, which could be either clogged or have lazy fans. THe condenser will get hot under normal use, but it shouldn't give you 2nd or 3rd degree burns.
I noticed a lot of dirt and dry mud in the condensor fins, cleaned it up, testing to see if any difference
