Brake Bleeding Sequence
Old Aug 14, 2007 | 01:01 PM
vinuneuro's Avatar
Default Brake Bleeding Sequence
I thought you always start from the caliper furthest away from the master cylinder. The helms sequence is very different.
5g Helms:
Old Aug 14, 2007 | 01:33 PM
preludestud11's Avatar
Default Re: Brake Bleeding Sequence (vinuneuro)
yes i noticed that also. in the helms for a 5th gen it says lf, rf, rr, lr for a 4th gen it says rr, lf, lr, rf hehe i just follow the manuel when i do my diffent cars.
Old Aug 14, 2007 | 02:04 PM
mgags7's Avatar
abs changes things up significantly as you can see.
turns out the abs unit makes the front lines significantly longer than the rears, just because they don't go thru the abs unit first.
the 5g is changed again because the abs unit is in a different spot
Old Aug 14, 2007 | 02:06 PM
vinuneuro's Avatar
Default Re: (mgags7)
i figured following helms would be a solid idea thanks fellas
Prudz_lude
Suspension & Brakes
Sep 8, 2008 08:45 PM
Daemione
Mar 6, 2006 08:32 AM
Drag-Accord
Jan 9, 2005 11:02 AM
Que_Lude
Aug 14, 2003 03:00 PM
viperguy
Apr 14, 2003 05:18 PM
