Catalytic Converter
Old Aug 14, 2007 | 12:31 PM
girliehonda's Avatar
Default Catalytic Converter
Are D-series and B-series Catalyic Converter the same length?
Old Aug 14, 2007 | 12:41 PM
dizzzane's Avatar
Default Re: Catalytic Converter (girliehonda)
No. The header on a d series and b series are not the same length.
Old Aug 15, 2007 | 07:03 AM
Default Re: Catalytic Converter (MilanoRed_dc2)
whats a good OEM replacement with a 2.5 in and outlet?
Old Aug 15, 2007 | 07:09 AM
crazyguy's Avatar
a test pipe would work but for oem.get a oem gsr cat
i have the same problem when i swapped a b16a into my eg.i am running stock b series header and it wont fit onto d series cat flange.so i had to bring it to a muffler shop to have them rewelded the flange
Old Aug 15, 2007 | 01:00 PM
Default Re: Catalytic Converter (crazyguy)
thanks for sharing your experiences with me. see most people on here usually just say take it to a shop and they do it but i would like to know so i will understand.
good info. thank you.
i will probably measure mine when i get a chance.
Old Aug 15, 2007 | 01:02 PM
HarfordCTR's Avatar
Or a Catco
Old Aug 15, 2007 | 01:34 PM
JKov240's Avatar
Default Re: Catalytic Converter (HarfordCTR)
Random Technology makes pretty good hi-flow cats
Regardless, somebody's going to have to cut and weld, unless you can find a cat that is the proper length
TeamRED_07
Southern California
Jul 14, 2016 04:09 PM
covpride
Nov 25, 2011 05:59 PM
GSRkid123
Feb 28, 2008 04:10 AM
The Mista Mike
Aug 25, 2004 02:10 PM
