Skunk2 tb Coolant Passage?
Hey, I got the 70mm Skunk2 TB, and it doesn't seem to have anywhere for the coolant lines to go. So, I have two questions:
1.) Am I a retard? Is there an obvious way to run coolant through the Skunk2 TB?
2.) If not, what should I buy to bypass the coolant? I'm about to run to the hardware store, in about ten minutes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALC!_JUST_du_IT! »</TD></TR><TR><TD CLASS="quote">Hey, I got the 70mm Skunk2 TB, and it doesn't seem to have anywhere for the coolant lines to go. So, I have two questions:
1.) Am I a retard? Is there an obvious way to run coolant through the Skunk2 TB?</TD></TR></TABLE>
Nope. Most aftermarket throttlebodies don't have the coolant passage, whereby you'll need to bypass it.
2.) If not, what should I buy to bypass the coolant? I'm about to run to the hardware store, in about ten minutes. </TD></TR></TABLE>
Take note of the hose that goes from the back of the intake manifold to the throttlebody, and the one that goes out of the throttlebody. Now what you need is some vacuum hose to replace those two hoses in order to bypass the throttlebody. Easy as pie, I just did it with mine.
D16SohcVtec
Sep 27, 2008 06:18 PM
