glove compartment broken
so I have a really big dilemma. the glove comparment locks onto a metal piece and that piece broke off of the car. What am I looking at to fix it?
Re: glove compartment broken (oddmut)
take off the glove box and go here...
http://www.slhondaparts.com
http://www.hondapartsdeals.com
shouldn't be that tough of a fix
Re: glove compartment broken (95ProjectEJ1)
i'm not sure what section it would be under... the glove box is off. the latch is broken which needs fixing and the metal piece the latch locks onto is broken off the car.
This is for the 95 SI...
http://www.slhondaparts.com/im...5.jpg
The GC latches onto #25 - 77542-SR3-000 STRIKER, GLOVE BOX
Hope this helps...
JasonGhostz
Hope this helps...
JasonGhostz
H-T White Ops
If you go to hondapartsdeals.com, go to the page you need and then click on Click Here for Enlarged View. Another window will pop up with an enlarged view. Now right click on that and select Copy Image Location. Paste that url into your browser window. You'll get a HUGE image.
Re: glove compartment broken (NOFX)
not here to thread jack but is a "GUARD, DOOR EDGE" the same as the side molding? I need one for my EBP Si. http://www.slhondaparts.com/br...ERIOR
Re: glove compartment broken (EM1SON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1SON »</TD></TR><TR><TD CLASS="quote">not here to thread jack but is a "GUARD, DOOR EDGE" the same as the side molding? I need one for my EBP Si. http://www.slhondaparts.com/br...ERIOR </TD></TR></TABLE>No. It's a thin, color-matched guard that replaces the rubber strip that's glued to the Door's Edge.
The part to which you are referring is in the Interior & Bumper section, and is called the "Protector".
http://www.slhondaparts.com/br...ECTOR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">If you go to hondapartsdeals.com (or slhondaparts), go to the page you need and then click on Click Here for Enlarged View. Another window will pop up with an enlarged view. Now right click on that and select Copy Image Location. Paste that url into your browser window. You'll get a HUGE image.</TD></TR></TABLE>I still can't believe more people haven't figured this out. Thanks to NOFX's instructions, hopefully more people will...
Hope this helps
JasonGhostz
Hope this helps
JasonGhostz
Re: glove compartment broken (JasonGhostz)
thanks man.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonGhostz »</TD></TR><TR><TD CLASS="quote">This is for the 95 SI...
Hope this helps...
JasonGhostz</TD></TR></TABLE>
part 25 connects to a a hard plastic. That part is broken. which part is it to replace? If not i was thinking of making two metal pieces to replace it.
Hope this helps...
Eibach95Civic
05-02-2007 05:00 PM
