Engine name for 06 Accord 4cyl?
Old Aug 14, 2007 | 10:23 AM
mizzoEG's Avatar
Default Engine name for 06 Accord 4cyl?
Hey guys, whats the engine name for a 06 accord 4 cylinder sedan?
is it a good idea to swap it into an eg hatch?
it looks like a b series to me but im not sure and i can't seem to find a website with the right info i need, does anyone know any good links?
thanks
Old Aug 14, 2007 | 10:29 AM
BlueIntegraBoy's Avatar
Default Re: Engine name for 06 Accord 4cyl? (mizzoEG)
K24A8
* Found in:
o 2006/2007 Honda Accord
+ Displacement: 2354 cc
+ Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
+ Compression: 9.7:1
+ Power: 166 hp (124 kW) @ 6000 RPM
+ Torque: 160 ft·lbf @ 4250 rpm
+ Redline: 6500 rpm
Info from wikipedia, so don't know how accurate this info is.
Old Aug 14, 2007 | 10:42 AM
Mr.EGo's Avatar
yup like blueintegraboy says, wikipedia.org
Old Aug 14, 2007 | 12:11 PM
crazyguy's Avatar
also element and crv share the same engine
k24a engines.
k24a engine in eg.it can be done but cost twice as more than b series engines
Old Aug 14, 2007 | 04:51 PM
mizzoEG's Avatar
man.. i was just wondering, what series of engines are considered the most powerful of four bangers from honda?
and whats your opinion of what sort of engine i should look into in cases of saving money and making satisfying power?
Old Aug 14, 2007 | 04:56 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG &raquo;</TD></TR><TR><TD CLASS="quote">man.. i was just wondering, what series of engines are considered the most powerful of four bangers from honda?
it's hard to catergorize which is the most powerful.
H and K series will have to be up there IMO, but it all depends on the type modification you plan on doing.
and whats your opinion of what sort of engine i should look into in cases of saving money and making satisfying power?</TD></TR></TABLE>
once again it all depends on the type of car ypu are planing on making. N/A, FI, and so on. IMO, any b-series will do fine.
Old Aug 14, 2007 | 05:07 PM
mizzoEG's Avatar
my car is a 94 dx hatch that needs much replacing.
i was just asking for a heads up on a not-so-exspensive potential engine thats got good kick and maybe even plans for forced induction in the future.
Old Aug 14, 2007 | 05:09 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG &raquo;</TD></TR><TR><TD CLASS="quote">my car is a 94 dx hatch that needs much replacing.
if you plan on going FI, then this is what i suggest (starting with the cheapest).
B18B
B16A
B18C.
Old Aug 14, 2007 | 07:02 PM
NOFX's Avatar
H-T White Ops
i was just asking for a heads up on a not-so-exspensive potential engine thats got good kick and maybe even plans for forced induction in the future.</TD></TR></TABLE>
Don't look at any K-series engines if you want something cheap. Even if you get one for free, they're not that cheap to swap in compared to other engines.
Old Aug 14, 2007 | 08:11 PM
01_CLtypeS's Avatar
look around in here: https://honda-tech.com/zerothread/878010
and when you make a choice on a motor you want look here: http://hmotorsonline.com/shop/...gines
Old Aug 14, 2007 | 08:22 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Engine name for 06 Accord 4cyl? (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
Don't look at any K-series engines if you want something cheap. Even if you get one for free, they're not that cheap to swap in compared to other engines.</TD></TR></TABLE>
Nonsense, K-series swaps can be done for $3000.
So as some people on the forum will digress.
Yes, K-series is an expensive route. Every budget k-series swapper I've met has yet to get back to me on how "uber-cheap" their swap was.
The k24 won't directly swap in to any car before 01. It requires a lot of special parts. Mount brackets, Drilling holes in the firewall to run cable shifters, custom or modified header, tuning/k-pro, axles etc etc. It all adds up to be $8000-10,000. The cheapest I've heard a budget k-swap done for was about $5000 with the installed already having a lot of the parts. A Frankenstein k-swap is likely to be even more-so expensive.
A fantastic engine, and well worth it if you have the money. But Unless you have deep pockets, don't plan on it being anywhere near cheap or bang for the buck.
violetteague
Jan 25, 2015 08:51 PM
96_Accord_lx
Jul 26, 2008 12:28 AM
DuceDuceCb
Oct 29, 2006 10:55 PM
NACvicSi
Oct 28, 2005 11:17 AM
SAPPHIREblue6SPEED
Jul 13, 2004 01:27 AM
