Engine name for 06 Accord 4cyl?
Hey guys, whats the engine name for a 06 accord 4 cylinder sedan?
is it a good idea to swap it into an eg hatch?
it looks like a b series to me but im not sure and i can't seem to find a website with the right info i need, does anyone know any good links?
thanks
thanks
Re: Engine name for 06 Accord 4cyl? (mizzoEG)
K24A8
* Found in:
o 2006/2007 Honda Accord
+ Displacement: 2354 cc
+ Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
+ Compression: 9.7:1
+ Power: 166 hp (124 kW) @ 6000 RPM
+ Torque: 160 ft·lbf @ 4250 rpm
+ Redline: 6500 rpm
Info from wikipedia, so don't know how accurate this info is.
* Found in:
+ Redline: 6500 rpm
also element and crv share the same engine
k24a engines.
k24a engine in eg.it can be done but cost twice as more than b series engines
k24a engines.
man.. i was just wondering, what series of engines are considered the most powerful of four bangers from honda?
and whats your opinion of what sort of engine i should look into in cases of saving money and making satisfying power?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG »</TD></TR><TR><TD CLASS="quote">man.. i was just wondering, what series of engines are considered the most powerful of four bangers from honda?
it's hard to catergorize which is the most powerful.
H and K series will have to be up there IMO, but it all depends on the type modification you plan on doing.
and whats your opinion of what sort of engine i should look into in cases of saving money and making satisfying power?</TD></TR></TABLE>
once again it all depends on the type of car ypu are planing on making. N/A, FI, and so on. IMO, any b-series will do fine.
my car is a 94 dx hatch that needs much replacing.
i was just asking for a heads up on a not-so-exspensive potential engine thats got good kick and maybe even plans for forced induction in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG »</TD></TR><TR><TD CLASS="quote">my car is a 94 dx hatch that needs much replacing.
if you plan on going FI, then this is what i suggest (starting with the cheapest).
B18B
B16A
B18C.
B18B
B16A
B18C.
H-T White Ops
i was just asking for a heads up on a not-so-exspensive potential engine thats got good kick and maybe even plans for forced induction in the future.</TD></TR></TABLE>
Don't look at any K-series engines if you want something cheap. Even if you get one for free, they're not that cheap to swap in compared to other engines.
look around in here: https://honda-tech.com/zerothread/878010
and when you make a choice on a motor you want look here: http://hmotorsonline.com/shop/...gines
Ek Forever y0!
Re: Engine name for 06 Accord 4cyl? (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">
Don't look at any K-series engines if you want something cheap. Even if you get one for free, they're not that cheap to swap in compared to other engines.</TD></TR></TABLE>
Nonsense, K-series swaps can be done for $3000.
So as some people on the forum will digress.
Yes, K-series is an expensive route. Every budget k-series swapper I've met has yet to get back to me on how "uber-cheap" their swap was.
The k24 won't directly swap in to any car before 01. It requires a lot of special parts. Mount brackets, Drilling holes in the firewall to run cable shifters, custom or modified header, tuning/k-pro, axles etc etc. It all adds up to be $8000-10,000. The cheapest I've heard a budget k-swap done for was about $5000 with the installed already having a lot of the parts. A Frankenstein k-swap is likely to be even more-so expensive.
A fantastic engine, and well worth it if you have the money. But Unless you have deep pockets, don't plan on it being anywhere near cheap or bang for the buck.
NACvicSi
10-28-2005 11:17 AM
SAPPHIREblue6SPEED
07-13-2004 01:27 AM
