D15B a hatch..
I have a 91 si with bent valves... and instead of having to deal with it i want to buy a D15B motor... but it only come with
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
What else do i need and what could i use from my car on that one??? thanks
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IP RACING »</TD></TR><TR><TD CLASS="quote">a different ecu.( cant remember which one) swap to multi point and might as well go obd1 to run vtec. thats about it</TD></TR></TABLE>
He's already MPFI, no need for that.
You'll need a new ECU, but I would recommend that you convert to OBD1 as well. That means you'll need an OBD0->OBD1 jumper harness and an OBD1 ECU for a D16Z6 I believe (not sure on the code).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huntley2147 »</TD></TR><TR><TD CLASS="quote">i plan on useing my tranny.. lol would it work?</TD></TR></TABLE>
hahaha yes yes it will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huntley2147 »</TD></TR><TR><TD CLASS="quote">can you explain how to do it? or can i search it and find it?</TD></TR></TABLE>
You answered yourself Grasshopper. Good on ya!
my car has the engine harness from an 89 si so im not sure if they are the same or not. anyways here is how mine is:
Small plug- the colors match. you just have to take the obd1 clip from the engine harness side and re pin it so it will plug in
Big plug- all the colors matched but one, and that is the thick white wire. take the obd1 clip from the engine harness side and re pin it so all of the colors match except that one. and that should be thick white(engine harness side) to yellow/green(dizzy plug side)
hope this helps.
hope this helps.
munchies91crx
34
Sep 20, 2009 05:59 AM
LorenGeist
12
Oct 6, 2004 06:30 AM
