vtec not working--ecu is throwing code 22...
its the vtec oil pressure code right? what should i check? also, is the pr3 supposed to blink once before you turn it on? because that's what mine does, hopefully i don't have to get a new 02 sensor...
Since that wire is one of the wires you have to add to the harness, I would make sure that wire is in good order and going to the right spot.
Most likely it's not connected right.
If you have a VTEC controller, specially APEX, it's bound to happen.
I don't know why or how to fix it, but I know of two guys with B16's and APEX who constantly throw code 22.
The oil press switch very rarely goes bad.
PnkRokCountryboy
Sep 2, 2007 02:21 PM
