Are all B Series Oil Squirters the same?
I have a B18C1, need new oil squirters for the block (machine shop bent mine, 2 snaped off and were in my oil pan). The B16 ones are way cheaper from the Honda dealership than the Acura ones. Anyone know if these are the same for both b series motors?
Modified by 4EN[sic] at 9:36 AM 8/14/2007
They're not all the same, but one of the results I found for GS-R oil squirters matched the part # for the squirters on an Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 »</TD></TR><TR><TD CLASS="quote">They're not all the same, but one of the results I found for GS-R oil squirters matched the part # for the squirters on an Si.</TD></TR></TABLE>
yea, was going to say you should find the part numbers and cross reference them to see if they match?
or just talk to a honda mechanic and see if they will tell you they are the same or not
The part number of the GSR one is 15280-P72-000 and the Si part number is
15280-PR3-000. I am just not sure if the 5 digits in the begining make it the same or if the 3 in the center make it different.?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJA-EG »</TD></TR><TR><TD CLASS="quote">you should get the HIGH-performance oil squirters</TD></TR></TABLE>
I believe he is being sarcastic.
Let us know if all b-series squirters are the same, we are all curious.
Honda will create different part numbers for the same exact part sometimes when it is in a different vehicle, doesn't always mean the part is different form, fit, function.
i put b16 oil squirters in my gsr block and it worked...i had to grind off a lttle part of the bolt so the ls crank would not it it though...but let us know if it is different so i will let the guy who bought my car now he needs to change them out
hmtcrxsir
Jun 20, 2009 02:49 PM
