idle problem
Old Aug 13, 2007 | 08:20 PM
b16a3delsol's Avatar
Default idle problem
Im having an idle problem on my b16. It sits around 1100 at the lowest but is usually around like 1400. I cleaned my IACV and my FITV. What else could be the cause of that? I also have checked for vaccum leaks and dont have any. Thanks
Old Aug 13, 2007 | 09:04 PM
Default Re: idle problem (lsdelsol)
need some kind of help plz
Old Aug 13, 2007 | 09:07 PM
se_hatchback's Avatar
did it ever idle fine? if not, first make sure your throtle body isnt getting stuck open just a lil, or theres a screw on the face of the throtle body that also controls the idle... you can also check your timing... if its not anything like that you might have to check your intake manifold and throtle body... hope this helps...
Old Aug 13, 2007 | 09:11 PM
Default Re: idle problem (se_hatchback)
i just this week finished the swap. Is it the big screw on the front of the throttle body. The high idle just bugs me or otherwise i wouldnt worry about it. thanks
Old Aug 14, 2007 | 12:15 PM
mistahmac's Avatar
there is a screw on the side of the tb to adjust the idle. stand on the pass side of the car and its up above the intake on the tb.
Old Aug 14, 2007 | 12:18 PM
dizzzane's Avatar
You could very easily have a bad TPS or one that needs adjusting.
Old Aug 14, 2007 | 02:41 PM
Default Re: idle problem (MilanoRed_dc2)
i know i need to adjust my tps but i have it pretty close right now. i think
Old Aug 14, 2007 | 02:42 PM
anywho my is good now so i guess i must have everything lined out good
Old Aug 15, 2007 | 09:29 AM
dizzzane's Avatar
Good deal.
TegraD
May 15, 2009 02:55 PM
mad21kid
Feb 18, 2008 12:52 PM
924doorEG
Nov 19, 2007 08:15 AM
gutted-dx
Dec 18, 2005 09:08 PM
vtec94civic
Aug 9, 2005 03:35 PM
