J's Racing Intake Installation - BRACKET
Old Aug 13, 2007 | 04:19 PM
honda_coupe's Avatar
Default J's Racing Intake Installation - BRACKET
I have had the J's racing intake installed. But i never have installed the bracket. The intake seems to rest on the coolant line causins it to obviously get warm.
Can anyone show me how the bracket bolts up?
Old Aug 13, 2007 | 09:35 PM
RiceKillinSI's Avatar
Default Re: J's Racing Intake Installation - BRACKET (honda_coupe)
On my ek i just bent the little L bracket and bolted it up to my transmission ground bolt. I don't know if that is where it supposed to go or not but it worked pretty good for me.
Old Aug 14, 2007 | 03:04 AM
Default Re: J's Racing Intake Installation - BRACKET (RiceKillinSI)
up! anyone else with input or pics?
Old Aug 14, 2007 | 07:09 AM
alocc_Cuhx's Avatar
what car do u have this installed in? i dont know how to explain it..how i mounted it..but ill get pictures up for u soon..just to give u an idea
Old Aug 14, 2007 | 07:14 AM
andoxviii's Avatar
Come to think of it, I never installed the bracket on my intake either...I should probably check if it sits on the rad hose, as that would warm the air quite effectively lol.
Thanks for the heads up and yes, pictures would be good
Free bump!
Old Aug 14, 2007 | 07:23 AM
Syndacate's Avatar
Default Re: (andoxviii)
I've seen a few of them installed (PS: I'm speaking from a pure tech aspect here and I hate them in every way possible).
Out of all of them I've seen (maybe 4, 5, 6?) only one had the bracket, and that was like RiceKillinSI said, it was just bolted onto the trans - I'm pretty sure on that ground you can remove to get easier access to the lower thermostat bolt. I wasn't really examining it. I also saw another setup with a bracket, his intake was "the same" - but it wasn't a "J's racing" one - same shape though, point simply being, he had a welded bracket and drilled two holes that ran to in front of your strut tower is (there's holes all over that).
Sorry I can't help further, I've seen quite a few pple put them on for their weekend race day - but I've only seen the bracket that comes with it once...and to be honest I didn't even know that came with it...I just thought he fabbed a bracket from some place, but now that makes sense. The other guy I saw with a bracket def. had a fabbed setup.
. I think ur safe to just let it "sit."
Old Aug 14, 2007 | 02:16 PM
Default Re: (Syndacate)
good info thanks guys.
Wish i still had a pic tho
Old Aug 14, 2007 | 03:05 PM
alocc_Cuhx's Avatar
well mines came with a bracket and my boi who has one didnt..but i know someone who can make it for u..he made one for my boi..he copied the one that i alredy had and its well worth it..becuh it was hittin on my lines..and in my bois ride it was hitting his AC lines..and it messed up are filters..but since ive got the bracket in..its been good ever since..it keeps it where it needs to be..but ill get pictures up ASAP
Old Aug 14, 2007 | 03:07 PM
alocc_Cuhx's Avatar
how do i post pic? LOL
Old Aug 14, 2007 | 03:24 PM
Default Re: (alocc_Cuhx)
upload it to photshop or something, or awebsite and right click it and find the URL under properties. Then click the little mountain pic [IMG][/IMG] post the URL of the picture in the IMG things lol
Old Aug 14, 2007 | 07:19 PM
This is similar to what I did..... kind of. If you bend the small L bracket just right and bolt the lower part of the bracket to the tranny ground the bracket will be under the intake and it is harder to see. Much cleaner.
http://www.brokenlimits.com/20...e.htm
Old Aug 14, 2007 | 07:35 PM
Great find! Thanks very much!
Old Aug 14, 2007 | 10:09 PM
Not a problem. Google Knows ALL!!!! LOL!!
ComCool
Jul 2, 2006 01:44 PM
SiCiViC2000
Mar 14, 2006 12:23 PM
jonoknut
Apr 14, 2003 08:51 PM
