Precision SC34 Turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18tegg »</TD></TR><TR><TD CLASS="quote">really intrested. so bare with me.
what would you prefer?
sc61 or this turbo...
It depends on your goals. The sc61 will support more top end hp however this will spool much quicker and give you a much wider powerband. This will give you a lot more usable power for daily driving.
http://www.precisionturbo.net/...=3026
you'll find all specs for the 2 models of the 34 avail here, similar specs for both and same HP rating which stands at 545hp.
I have the SC6152E and for my Built LS/Vtec setup, I dont make full boost till 5000rpm and the SC61 is rated for upwards and around 650hp no one will ever see that on here with a journal bearing turbo. i think i would like the SC34 much better than the SC61
do you recall where the car made full boost???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joey Tribianni »</TD></TR><TR><TD CLASS="quote">http://www.precisionturbo.net/...=3026
do you recall where the car made full boost???</TD></TR></TABLE>
Full boost was made around 4k rpms on my b16.
I just want something I can make 500-530 with out having to worrie to much about lag.
its for a fully built sleeved gsr.
I still cant make up my mind. i'll let you know thanks for the patience and answers
i'd say around 24psi should give you mid to high 400 horse with very little lag, The GSR has a bit more displacment that the B16A and a heavier lobe so my best guess would be full boost around 3600 which is not far away from no lag at all. Wanna trade for a SC6152E?
killablaze
Nov 17, 2004 07:22 PM
