Honda S2000 Honda S2000
oil consumption
Old Aug 13, 2007 | 03:01 PM
67marobird's Avatar
Default oil consumption
When I first bought my 03 S2K from an Acura dealer, it was about a quart low, though the oil was clean. I got in a wreck (documented here), got it back and changed the oil immediately to 5.2 quarts of Royal Purple and a PureOne filter. 1500 miles later, I'm a quart down again (well, added the 0.8 that was left), and the oil is squeaky clean. I'm sure it was dino oil in the car when I got it (dealer change) -- I figured they just didn't put enough in.
Is this common? I also bought a 4/48K mile warantee through Acura on it. Any recourse there? The car only has 26K on it.
Thanks guys-
Tom
(on the road again and using oil)
Old Aug 13, 2007 | 03:45 PM
avallach's Avatar
Default Re: oil consumption (67marobird)
I got my 01 at 26K. I'm at 32k. I immediately changed the oil -- Mobil1/OEM filter and like you was consuming alot of oil 1 quart/1K miles. I just did another oil change 1K miles ago. And now I'm can barely detect any oil consumption. The car's been on dino with the first owner...my driving hasn't changed -- actually it's gotten more aggressive as I got better with the car.
Don't know if it's common, but anything within a quart of consumption within 3K miles is not unusual.
Old Aug 13, 2007 | 06:04 PM
s2kdre's Avatar
Default Re: oil consumption (avallach)
alot of s2k's burn synthetic, try regular oil, or get some crank vents. my 04 s2k has 54k and never burned a drop, not even a 1/2 quart between changes, i use castrol gtx btw!
Old Aug 13, 2007 | 06:25 PM
Agent Zero's Avatar
Default Re: oil consumption (s2kdre)
It is pretty common with the S. If I get peddle happy I will burn some oil. So unless you are burning a ton of oil don't sweat it.
Old Aug 13, 2007 | 06:56 PM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">alot of s2k's burn synthetic, try regular oil, or get some crank vents. my 04 s2k has 54k and never burned a drop, not even a 1/2 quart between changes, i use castrol gtx btw!</TD></TR></TABLE>
Mine burns ZERO with synthetics and a catch can. Very little end up in the can, though.
Old Aug 13, 2007 | 07:06 PM
b20integrapower's Avatar
Default Re: oil consumption (Mr. Projekt)
i burn oil. Its cause my car is too fast
Old Aug 14, 2007 | 07:59 PM
67marobird's Avatar
Default Re: oil consumption (b20integrapower)
...so if I brought it to the dealer with this complaint under my extended warantee, I can expect to be told to F off?
Old Aug 14, 2007 | 09:07 PM
ProjectDarkBlack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 67marobird &raquo;</TD></TR><TR><TD CLASS="quote">...so if I brought it to the dealer with this complaint under my extended warantee, I can expect to be told to F off?
not necessarily. But it would be hard to prove
VQ's have been recalled because of it. Like they said as long as it is reasonable it won't matter
Old Aug 16, 2007 | 07:10 AM
jonnys2k's Avatar
Default Re: oil consumption (ProjectDarkBlack)
hey... havent posted here before... i usually stay on s2000turbo.com... but its been rly slow lately...
so this happened to me not to long ago.. i went on a trip to upstate pa... was doing about 140 most of the way... and when i got back from the trip i noticed my oil was low..(changed oil a week prior to leaving) so i put some royal purple in.. it took 3 courts??? is that normal to burn that much oil???
Old Aug 16, 2007 | 07:28 AM
SilverDc2's Avatar
Default Re: oil consumption (jonnys2k)
i was burning 1.5 q with mobile 1, valvoline .75-1 q 3500-4000 miles.
im running royal purple hasn't burned yet at 1500
Old Aug 16, 2007 | 08:28 AM
* B A N N E D *
Default Re: oil consumption (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">
im running royal purple hasn't burned yet at 1500 </TD></TR></TABLE>
Swear by this stuff.
Old Aug 16, 2007 | 10:07 AM
jonnys2k's Avatar
thats wat i had in the car when it burned 3 courts! i still love the stuff.. but i burned an awful lot!!
Old Aug 16, 2007 | 10:17 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnys2k &raquo;</TD></TR><TR><TD CLASS="quote">thats wat i had in the car when it burned 3 courts! i still love the stuff.. but i burned an awful lot!!</TD></TR></TABLE>
That's the first I heard of Royal Purple. Then again, they do put a lot of detergent in it. It probably cleaned the hell out of your motor. People who have used it on newer lower mileage motors have had no complaints. :shrugs:
Old Aug 16, 2007 | 02:27 PM
g2kap1v2's Avatar
honda manual says to check oil after a tank of gas...I always check and i always put in a lot of oil....(car hasen't gone a day below 8k)
Old Aug 16, 2007 | 05:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnys2k &raquo;</TD></TR><TR><TD CLASS="quote">hey... havent posted here before... i usually stay on s2000turbo.com... but its been rly slow lately...
so this happened to me not to long ago.. i went on a trip to upstate pa... was doing about 140 most of the way... and when i got back from the trip i noticed my oil was low..(changed oil a week prior to leaving) so i put some royal purple in.. it took 3 courts??? is that normal to burn that much oil???</TD></TR></TABLE>
you were doing 140 most the way? LOL
thats quite a bit of load for an extended period. Suprised your tires didn't overheat as well. Remind me not to buy your car
Old Aug 16, 2007 | 10:14 PM
Mike1995HondaPrelude's Avatar
LOL. seriously, what were you thinking. thats WAY TOO FAST.
Old Aug 17, 2007 | 12:38 AM
jonnys2k's Avatar
Default Re: oil consumption (Mike1995HondaPrelude)
way to fast??? yea rite... not fast enough... the car can handle it.. tires were fine... z rated tires... the car is ment to be driven.. not babied
Old Aug 17, 2007 | 06:34 AM
orangebarius's Avatar
buy krankvents. they stopped my oil consumption. i used to burn 1 quart every 1000 miles and now i burn none.
http://www.s2ki.com/forums/ind...52783
Old Aug 22, 2007 | 06:09 PM
S27sam's Avatar
Default Re: oil consumption (orangebarius)
I bought a totaled car (for a project) that was about 3 quarts low when I got it. I was pretty dissapointed, but couldn't find any signs of leaks and after I filled the oil and started it, it still ran nice and smooth. Hopefully it wasn't too far past its time for a change.
Old Aug 24, 2007 | 10:40 PM
Shy_GuyAP1's Avatar
Mine is always fine, I don't think it burns any, but I was told that it says in the manual they burn a quart between changes.
I haven't looked it up, but next time I'm looking through it I'll try to find a page number to cite.
Thomas ander
Honda Accord (2013 - 2015)
Mar 1, 2019 09:49 AM
Buzzbomb
Dec 8, 2007 04:31 PM
Solo2Vtec
Honda Civic (2006 - 2015)
28
Jan 22, 2007 02:32 PM
Behan
Sep 9, 2003 05:10 AM
Puki
May 19, 2003 11:56 AM
