ABS Elimination Questions on 95 GSR
Old Aug 13, 2007 | 12:43 PM
501hpintegra's Avatar
Default ABS Elimination Questions on 95 GSR
I would think there was a post So I apologize in advance if there is but I would like some help eliminating my ABS on my Teg. If someone could provide some friendly help I would be in great appreciation.
1.I would like a parts list
2. maybe someone makes a kit
3. if they could direct me to the discriptive post that shows you step by step
Thanks for all the help
Old Aug 13, 2007 | 02:00 PM
ls19integra95's Avatar
Default Re: ABS Elimination Questions on 95 GSR (501hpintegra)
just did this on my 95 ls, you need an rs brake booster and master cylinder for non abs, and then you need a 40/40 prop valve, and 4 brake lines, 2 that goes form the master cylinder to the prop valve and 2 that go from prop valve to the front wheels...
Old Aug 13, 2007 | 02:03 PM
Default Re: ABS Elimination Questions on 95 GSR (ls19integra95)
Part #'s would be great. Now this is all bolt up stufff and I can remove all the sensors, relay box and wiring right?
speed_demon018
Dec 15, 2012 07:11 AM
mmcsiggi
Suspension & Brakes
Nov 2, 2010 12:20 PM
95civic_ls_vtec
Jun 16, 2010 02:13 PM
dc4teg95
Feb 23, 2009 04:15 AM
xBoosted4drx
May 3, 2005 10:39 AM
