car wont start, cranks but wont turn over
Old Aug 13, 2007 | 12:13 PM
trix are for kids's Avatar
Default car wont start, cranks but wont turn over
95 GSR, bone stock
the car will keep cranking but wont start. this problem has been going on fro a while and we havent been able to find the cause. it has brand new ignition coil, new igniter, new cap and rotor, new spark plugs/wires. new battery. timing is correct with new timing belt and water pump. new alternator/ac/power steering belts. ecu is good. fuel is good. compression is 120/140/140/180 in the cylinders (i know low, but it should still start). alarm completely disconnected. we are lost, any help would be greatly appreciated, thanks
Old Aug 13, 2007 | 12:27 PM
superchi's Avatar
Default Re: car wont start, cranks but wont turn over (trix are for kids)
I feel like I'm stating the obvious, but when I had a crank/no start problem, one of my fuses were popped (I think it was for IGN?), so give the fuses a once over just to make sure.
Old Aug 13, 2007 | 04:46 PM
Default Re: car wont start, cranks but wont turn over (superchi)
thanks for the reply. fuses are good. any thing else you guy think?
Old Aug 13, 2007 | 04:57 PM
90DAkid's Avatar
check the main relay?
Old Aug 14, 2007 | 12:22 PM
Default Re: (90DAkid)
relay is good
Old Aug 14, 2007 | 01:19 PM
Beeda's Avatar
Default Re: (trix are for kids)
**** im having the same problem.
Old Aug 17, 2007 | 04:51 PM
ZkyLude's Avatar
Default Re: (Beeda)
Me too.. wow I found several other that have this similar won't start problem. What's going on?
https://honda-tech.com/zerothread?id=2072055
https://honda-tech.com/zerothread?id=2066945
https://honda-tech.com/zerosearch
Old Aug 17, 2007 | 10:27 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
check the spark plug wires and make sure current flows to the spark plugs
Old Aug 17, 2007 | 10:40 PM
davidluko's Avatar
Check if it's getting spark to the spark plugs and if the injectors are getting fuel. Once you find out with one is the problem, start going up the system and testing everything until you find the problem.
bart simpson
15
Apr 6, 2010 12:21 PM
EF909
27
Feb 27, 2010 01:30 PM
sneakerfern
Oct 29, 2007 06:01 PM
JDMoMo
Dec 27, 2005 09:42 AM
