clutch cable problems Please help!
I have a b18b with the cable to hydro conversion kit. My clutch cable snaped and I had a new cheap crx one put on. My clutch pedal was instantly rediculously stiff and now the clutch isn't engaging all the way. At a stop the car stalls and I can't get the car into any gears. The lever sticking out of the transmission that the conversion kit connects to is not moving over far enough to engage the clutch either. Please help asap! I have to drive it tomorrow, but it is not drivable. Also can I go with the 90-93 clutch cable? Oh and another thing is that the bracket is missing from my clutch cable as well.
Ahhh, get the bracket.
The stock cable should work fine with the bseries trannies... its a little long, but you can adjust to work. I use the stock 89 SI cable in my b16 hatch.
InJ3cted
May 24, 2005 02:16 PM
