ek trailing arms on a 91 si
Old Aug 13, 2007 | 09:45 AM
EFstyle's Avatar
Default ek trailing arms on a 91 si
is it posible? the bushings and such are in much better condition so i figured id see if i can just switch em.... plus its one less bolt on each side that id snap when i put in my suspension...let me know
Old Aug 13, 2007 | 09:57 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
i'm 99% sure they will not fit.
Old Aug 13, 2007 | 10:23 AM
EL Vap133's Avatar
Default Re: ek trailing arms on a 91 si (EFstyle)
88-00 Civic/CRX Trailing arms are the same.
Old Aug 13, 2007 | 11:56 AM
ComeOnKip's Avatar
(wipes egg off face)
Old Aug 13, 2007 | 12:00 PM
CRX Toad's Avatar
https://honda-tech.com/zerothread?id=1513752
http://crf50.no-ip.com/fourthg....html
Old Aug 13, 2007 | 03:40 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle &raquo;</TD></TR><TR><TD CLASS="quote"> plus its one less bolt on each side that id snap when i put in my suspension.</TD></TR></TABLE>
Are you confused? do you mean control arms? the suspension only attaches to the control arms not the trailing arm. The trailing arm will work but the control arm will NOT they are a lot longer
Old Aug 13, 2007 | 04:25 PM
VtecSyndrome's Avatar
Default Re: ek trailing arms on a 91 si (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Are you confused? do you mean control arms? the suspension only attaches to the control arms not the trailing arm. The trailing arm will work but the control arm will NOT they are a lot longer</TD></TR></TABLE>
x2, the trailing arms themselves will fit but not the other EK control arms
vtec4lyfe
Jan 6, 2007 09:33 AM
8point6
Suspension & Brakes
29
Aug 28, 2006 06:31 PM
divingcorners
Suspension & Brakes
Aug 17, 2006 10:00 AM
ham
Mar 15, 2004 03:16 PM
