94 Lexus SC300 5-speed! **$2500**
Old Aug 13, 2007 | 09:44 AM
1point7db2's Avatar
Default 94 Lexus SC300 5-speed! **$2500**
Well, I have some other things I need to worry about right now, and dont have the time for this car anymore.
Heres the deal- I bought the car and drove it for about a week, it ran great, rode awesome, shifted fine, the clutch grabbed like new. The leather is in great shape, I think at has been redone. I sent the car to the paint shop to get repainted where it sat for about 2 weeks. I go the car back, and it was running a little rough and smelled of fuel. I determined that it was a stuck injector that was filling one of the cylinders with fuel. I was in the process of replacing the bad injector when my freind decides its a good idea to pump the raw fuel out of the motor by turning it over. Well, it pumped it out, but at the same time ignited it causing a small fire. I have checked the entire harness, all this car will need is vacuum lines, and the connectors on the harness replaced. the fire was not bad enough to burn through the harness.
If you have the parts to fix this car, you could have a very clean sc3 5spd for cheap, with a brand new paint job. The car is green with tan interior. It has 169k. I beleive I am the 2nd or 3rd owner, I have its records, it was a Miami car. I also have the original window sticker.
I am located in Winchester, VA.
Sorry about the bad pics.
(540)-409-7719
Old Aug 13, 2007 | 11:23 PM
jfrase06's Avatar
pm me i have a few questions!
Old Aug 14, 2007 | 08:21 AM
owen_the_soyboy's Avatar
Default Re: (jfrase06)
that dog in your pic is hilarious.
bump just for that.
LOLz.
and someone buy this and drop in a 2jz please.
Old Aug 14, 2007 | 09:17 AM
Unsivil_audio's Avatar
^---since when do they NOT have a 2jz in them?
Bump for you and a good deal.
Old Aug 14, 2007 | 10:32 AM
1point7db2's Avatar
Default Re: (Unsivil_audio)
Yes, it has the NA version of the 2jzgte (2jz-ge). Do some research, these engines are essentially identical internally, throw a big snail on this NA motor, they are capable of BIG #'s on a stock block!
Old Aug 14, 2007 | 10:35 AM
rcjustin's Avatar
Default Re: (1point7db2)
how much are we talking about to fix all the damages to the car?
Old Aug 14, 2007 | 10:39 AM
1point7db2's Avatar
Default Re: (rcjustin)
I would say at MOST, if you do the work yourself, $700. I have already cleaned up the engine bay, removed damaged/burned items. I have taken the loom of the harness and traced and checked each individual wire, then retaped the whole thing. it just needs the connectors replaced.
I found an entire engine/harness/ecu on ebay for $450 + shipping. I needed the money for other things, so that fell through. Im sure the guy still has the stuff, I can put you in contact with him.
Old Aug 14, 2007 | 11:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point7db2 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it has the NA version of the 2jzgte (2jz-ge). Do some research, these engines are essentially identical internally, throw a big snail on this NA motor, they are capable of BIG #'s on a stock block!</TD></TR></TABLE>
This man speaks the truth.
Old Aug 16, 2007 | 07:43 PM
1point7db2's Avatar
Also open to trades...
Old Aug 17, 2007 | 10:49 PM
aka Paco's Avatar
damn man if i could sell my integra fast enough i'd be all over this, exactly what i've been wanting bump for a good deal
John McGinley
Feb 28, 2017 06:21 AM
p0tter7
Mar 3, 2014 10:37 AM
Lamafia ck
May 1, 2007 09:27 AM
aznej2
Sep 1, 2006 11:56 AM
Cornershop
Jul 3, 2002 11:02 PM
