BDL FUEL RAIL need help!!!!
Old Aug 13, 2007 | 08:41 AM
eg64u's Avatar
Default BDL FUEL RAIL need help!!!!
Ok so i purchased a new BDL fuel rail new from a member on ht, and everything is fine i believe. I go to install and everytghing gos normal, Then a day later it leaks, it leaks on one of the bolts that thread for the fuel pressure regulator. I dont know why bdl designed it this way, but only one of the holes out of the 2 go straight into the rail like fuel if that makes sense. So i put teflon tape on it (which i shouldnt have to) and that works great for another day, now im back with the same problem. I installed many rails before and this time its giving me trouble on my own car. gees sucks. haha
lmk with any solutions.
oh and side note. the ony holes that the rail has to the main fuel source is injectors, optional fuel pressure gauge hole (which i have one installed), and the in and out line at the ends of the rail, and also that one under the fpr and in one of the fpr bolt hols, kinda odd but lmk
thanks in advance
Old Aug 13, 2007 | 03:02 PM
Jdmb16sir2's Avatar
Default Re: BDL FUEL RAIL need help!!!! (eg64u)
you should post some pics they might help a little more.
Old Aug 13, 2007 | 05:39 PM
eg64u's Avatar
err, yea i guess i could i have to take apick first, im at work, but ill try to get a pic of any fuel rail and you will get what im talking about.
bump
Old Aug 14, 2007 | 11:00 AM
eg64u's Avatar
ill try to get pic's tonite. bump
Old Aug 14, 2007 | 02:28 PM
eg64u's Avatar
Default Re: (eg64u)
ok here is a pic, please check it out. fpg-fuel pressure gauge, fpr- fuel pressure regulator, .1- where it is leaking from, .2 is not leaking. 1 and 2 is where the fpr is bolted on at. Only bolt 1 is leaking. I can blow air through 1 and 2 but 1 is alot less restricted, i dont know why i can blow air through it in the first place. Its just made for bolts to go into, i never heard of any acces for fuel being in these holes, let me know what you guys think i should use to cause it from leaking. Oh and any help is much appreciated.
http://i190.photobucket.com/al...30293
Old Aug 14, 2007 | 04:57 PM
allmotaeg6's Avatar
Default Re: (eg64u)
help you out so people can check it out without opening a new window to view the pic
Old Aug 14, 2007 | 09:10 PM
eg64u's Avatar
Default Re: (allmotaeg6)
aprreciate it
Old Aug 16, 2007 | 05:10 AM
eg64u's Avatar
so get this guys, i find out that bdl makes the thread set shorter, and you are suppose to use shorter bolts, i told the bdl rep that it didnt have instructions to purchase or cut new ones to fit, he was aware of this, nowhere does it say to use shorter bolts, its litterally shy by less then 2mm i would say. but tahts enought to hairline crack it internally. fortunately bdl ind is cool about it and told me to send it back and they will send a new one. so thats cool i guess.
thanks everyone
cliff notes: bdl threads to short, need shorter replacement bolts when installing!!!
skUnK2jdm
Jan 30, 2007 12:00 PM
zCivic
Sep 7, 2006 02:42 PM
11mastamind11
Apr 25, 2005 10:05 AM
mister2racer
Apr 16, 2004 03:56 PM
thehondaguru
Oct 11, 2002 05:33 AM
