anyone here know how thick a gsr front swaybar is??
Old Jun 12, 2002 | 12:06 PM
supergreenNA1's Avatar
New User
Default anyone here know how thick a gsr front swaybar is??
just like the subject says. i need to know how thick a 94-00 gsr front swaybar is.
thanks.
Old Jun 12, 2002 | 12:30 PM
fubar's Avatar
Default Re: anyone here know how thick a gsr front swaybar is?? (supergreenSol)
24 mm
Old Jun 12, 2002 | 12:51 PM
JDMTEG98's Avatar
Default Re: anyone here know how thick a gsr front swaybar is?? (fubar)
Speaking of sway bars. It is worth replacing the stock one? I am assuming the Aftermarket will be stiffer, Correct? What brands or what should I look for in a aftermarket sway bar?
Old Jun 12, 2002 | 01:11 PM
Chris's Avatar
Default Re: anyone here know how thick a gsr front swaybar is?? (GSR1998white)
I liked my Suspension techniques. I think it was 25mm front and 19mm rear. Stock rear is 14mm IIRC.
Old Jun 12, 2002 | 01:19 PM
JDMTEG98's Avatar
Default Re: anyone here know how thick a gsr front swaybar is?? (Chris)
Where did you see improvements? Handling perhaps and sharp turns?
Old Jun 12, 2002 | 01:31 PM
New User
that's what i'm goin thru at the moment. i have a del sol with a 22mm front bar and no rear bar. i already installed the 22mm type r rear bar but am not sure what to do about the front bar.
i guess my next question is... what is the diameter of the type r front swaybar??
Old Jun 12, 2002 | 01:38 PM
Chris's Avatar
The sway bars reduced body roll and helped it to corner better, but I also shanged the shocks and springs at the same time, so I cannot comment on the bars alone.
Old Jun 12, 2002 | 03:20 PM
frogsr's Avatar
they help with all turns, but the sweeping turns (like fwy onramps for example) is where you'll really feel the difference. one of the best mods you can do with your suspension.
Old Jun 12, 2002 | 03:22 PM
JDMTEG98's Avatar
Default Re: anyone here know how thick a gsr front swaybar is?? (frogsr)
Lovely. Any brand Recommendations? I guess I would get all three Front, rear and rear lower
Old Jun 12, 2002 | 03:40 PM
frogsr's Avatar
just get the rear itr one. make sure you buy the proper bracket/mounting hardware, or you will have tear out problems as documented by many on this board. do a search.
Old Jun 12, 2002 | 04:01 PM
JDMTEG98's Avatar
SUSPENSION TECHNIQUES ????
Old Jun 12, 2002 | 04:47 PM
Project X's Avatar
ITR/GSR 24mm front sway, ITR 22mm rear sway, Cusco or Neuspeed front tie bar, lots of brand for the rear tie bar.
My next step would be JDM '98 Spec 25mm front / 23mm rear.
For the extreme, Mugen 26F/26R.
Old Jun 12, 2002 | 05:52 PM
BSQ's Avatar
BSQ
In stock an Integra (except the Type-R) has a handling characteristic of understeer (or "push"). Now if you want to change the handling characteristic to neutral (ie. no understeer and no oversteer ("loose") you will want to increase the size of the rear swaybar. This is why the Integra Type-R has a 22mm rear swaybar and the other Integra models have a 12mm or 14mm rear swaybar. The Integra Type-R is well know for it balanced handling (ie. neutral handling) and it is mainly because of the increased diameter of the rear swaybar.
I personally recommend only upgrading the rear swaybar and I prefer the Type-R rear swaybar. It is inexpensive (~$105-$110 for everything needed) and it can be bought at any Acura dealership.
If you would like further information on installing the Type-R rear swaybar, you can go to my webpage at http://www.geocities.com/bretq/swaybar_install.html.
[Modified by BSQ, 9:53 PM 6/12/2002]
Old Jun 12, 2002 | 07:28 PM
JDMTEG98's Avatar
Default Re: anyone here know how thick a gsr front swaybar is?? (BSQ)
BSQ: How do you feel about the Suspension Techniques Sway Bars Versus ITR Sway Bars. For a 1998 GSR
Diameter is 1 (25.4 Millimeters) Inch in front End
Diameter is 3/4 (19.05 Millimeters) Inch in Rear Sway Bar
Sold in a set for around $200.00
Let me know
Old Jun 12, 2002 | 07:39 PM
JDMTEG98's Avatar
Oh yeah you can also add one the trunk. Is that worth it??? I think that is a Strut Tower bar rather than sway bar or is it the same thing?
Old Jun 12, 2002 | 09:01 PM
Calavera's Avatar
Do all '94-97 LS/RS/GS/SE have a 22mm front sway bar like the GSR's?
Old Jun 13, 2002 | 07:35 AM
Project X's Avatar
Default Re: anyone here know how thick a gsr front swaybar is?? (Calavera)
No. GSR's 24mm. '96 LS-SE also is 24mm.
I believe RS and LS are 22mm.
Old Jun 13, 2002 | 07:58 AM
BSQ's Avatar
BSQ
I have no personal experience with the Suspension Technique swaybars so I really cannot comment on them directly. But if you were to compare their diameters (which affects torsional stiffness) the ST 19mm rear swaybar to the 22mm Type-R rear swaybar, the Type-R rear swaybar is ~80% stiffer than the ST.
I have read feedback from people who have installed the Neuspeed 19mm rear swaybar and they commented that they still noticed some understeer. Whereas, most people (including myself) that have installed the Type-R 22mm rear swaybar have commented that the handling is neutral (no understeer/no oversteer). So it really comes down to personal preference (ie. do you want understeer or neutral handling?). As mentioned before, I would not change the front swaybar. If you increase the diameter of the front swaybar (along with increasing the diameter of the rear swaybar) you will negate some of the handling improvements of adding the rear swaybar.
Cost wise the Type-R rear swaybar is nearly half the price of the ST.
Old Jun 13, 2002 | 10:06 PM
JDMTEG98's Avatar
Nicely put
Old Jun 14, 2002 | 07:37 AM
New User
anyone know if an integra front swaybar will fit on a del sol??
this is the last piece of the puzzle for me.
Old Jun 14, 2002 | 07:42 AM
BSQ's Avatar
BSQ
Yes. As long as the Integra front swaybar is from a '94-'01 it will fit on a Del Sol. The '94-'01 Integra share the same suspension with the '93-'97 Del Sol.
Old Jun 14, 2002 | 07:50 AM
New User
coo. thanks man.
Deam
Jun 29, 2004 01:07 PM
sol2nr
10
Feb 17, 2004 06:29 PM
EG_93Civic
Dec 1, 2003 07:03 AM
typeeg
Sep 26, 2003 04:50 PM
Gennady
Jan 11, 2002 05:30 PM
