Prelude JDM headlights question
Old Aug 12, 2007 | 08:18 PM
Entaka's Avatar
Default Prelude JDM headlights question
Does anyone have a the diagram/picture that is supposed to be here:
http://www.superhonda.com/foru...64230
Im trying to do a headlight install and wanted some peoples opinions. Is it worth the trouble to wire the H4 by its self for bright/low beams or does it make just as much sense to wire the H1 as high beam and only use the H4 for low beam? Sorry if I confused any one...Im slightly confused as well.
Old Aug 12, 2007 | 08:24 PM
no1knows908's Avatar
Default Re: Prelude JDM headlights question (Entaka)
If you decide to use the H4 for low beam and H1 for high beam PasswordJDM.com sells a plug and play conversion harness so you don't have to chop up your factory harness.
Old Aug 12, 2007 | 09:39 PM
Entaka's Avatar
Default Re: Prelude JDM headlights question (no1knows908)
Yeah i ordered some 9005/9006 harnesses and H4/H1 harnesses to make some myself so I dont have to chop with which ever way I go. The Low beam H4 and High beam H1 just seems to be easier.
Old Aug 13, 2007 | 11:47 PM
TrungBB6's Avatar
That **** is a bitch. I heloed my friend do it on his 4th gen. U gotta rig it and it will work.
Old Aug 14, 2007 | 06:12 AM
M2B4's Avatar
Default Re: Prelude JDM headlights question (TrungBB6)
not hard at all
Old Aug 14, 2007 | 09:34 AM
batkosio's Avatar
Default Re: Prelude JDM headlights question (M2B4)
Thanks, it will help me a lot!
Old Aug 14, 2007 | 03:52 PM
Si Speed's Avatar
I spliced mine just to be sure everything was how it should be. Used the H4 lows and H1 highs. No problems.
Old Aug 14, 2007 | 03:56 PM
M2B4's Avatar
Default Re: (si_speed)
dont splice i did that the 1st time this is what i did the 2nd time.
Old Aug 14, 2007 | 05:07 PM
snobordboy's Avatar
Moderator
Default Re: (M2B4)
I dunno about that, I personally like the safety of having my wiring properly soldered and heat shrinked so that no water gets in and the connection cant come loose. I just did h4 as lows and h1 as highs, works fine for me.
Old Aug 14, 2007 | 06:53 PM
cfran55's Avatar
Default Re: (snobordboi)
lol i really need to redo my wiring my driver side low never stays on unless i push on it before hand. Been to lazy to redo it
Old Aug 14, 2007 | 06:54 PM
M2B4's Avatar
Default Re: (cfran55)
i taped mine up with electric tape. worked fine since.
Old Aug 14, 2007 | 07:00 PM
cfran55's Avatar
Default Re: (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">i taped mine up with electric tape. worked fine since.</TD></TR></TABLE>
yea i spliced and crimped to female connectors and electric taped them but not good enough i guess
Old Aug 14, 2007 | 07:57 PM
InvaderTrax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">not hard at all
But wouldn't that give power to both the high and low filaments in the H4 bulbs when the highs are on? Because that can overheat the bulb
Old Aug 14, 2007 | 08:21 PM
Default Re: Prelude JDM headlights question (InvaderTrax)
<U>Borrowed from Honda Acura Forum</U>
For starters I have to say that "City Lights" H1 bulbs are very bright and should be used as a separate switch, could be combined with fog lights. This mentioned, let's concentrate on the H4 bulbs.
The trick here is to know the arrangement of the H4's since they have only 3 wires (GND, HIGH BEAM, LOW BEAM). The problem here is that our stock harness (USDM) have two cables per plug and not three as mentioned above. It was practically overwhelming when thinking on how to do this conversion; however, the trick was to know that the H4's don't have polarity. Either forward or reversed electric flow can be arranged.
Let's concentrate on the Left Headlight H4 bulb. You can see that on the H4 connector we have one common ground for both High Beam and Low Beams; therefore, taking a closer look at the Left Headlight we see that we have one common power source (Low/High). This said, man I can't help smiling , by connecting both Low/High wires together and soldering it to the negative connector on the H4 it will give you the a common Power Source to both High/Low beams just like the diagram. Finally, the Low Beam is connected to the Low Beam H4 connector and the High Beam is connected to the High Beam H4 connector.
RIGHT SIDE HEADLIGHT IS VICE VERSA - instead of Low/High wires you use the Low/High wires.
Sorry to use your picture but I THINK this is what this is trying to say.
Old Aug 14, 2007 | 08:25 PM
M2B4's Avatar
the way my pic shows it they already are sharing a ground
Old Aug 14, 2007 | 08:31 PM
prelude_h22vtec's Avatar
the jdm light harnesses actually have the same color wires, or similar at least. i wired same color to same color and mine have worked forever like that.
Old Aug 14, 2007 | 08:35 PM
though after seeing this, i may do the "city lights" thing
ef yu
Lighting
Mar 15, 2010 09:20 PM
monalisa overdrive
Nov 2, 2004 11:15 AM
ItzTw
Jan 29, 2003 08:10 PM
Bklyn TSi
Oct 23, 2002 01:54 PM
dcaccord
Feb 25, 2002 12:18 PM
