Can't find reverse !!!!
I recently swapped my d-series for a b and switched over the shift linkage and now for some reason i cant get it to go into reverse, sometimes i'll get lucky but 9 out of 10 times it wont. Any input will help thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black97DX »</TD></TR><TR><TD CLASS="quote">Can't find reverse !!!!</TD></TR></TABLE>
Move the shifter to the right, then pull back.
all the other gears work fine?
sometimes mine won't pop in and letting the clutch out and in a time or two helps.
get under the car and see if you can get it in reverse by moving the linkage. if you can then something is wrong with your shifter. if it doesn't it may be internal problems with your transmission.
yes i did buy used linkage and i have tried almost everyhting that you guys have said like today it doesnt want to go into 1st or 2nd, i might jsut try and pick a trans.... but idk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 »</TD></TR><TR><TD CLASS="quote">
sometimes mine won't pop in and letting the clutch out and in a time or two helps. </TD></TR></TABLE>
thats wat i have to do in my 92 si
skUnK2jdm
11
Dec 13, 2008 11:43 PM
jurenic
11
Mar 20, 2005 04:10 PM
