What year is my cable LS trans? I need a clutch!
Old Aug 12, 2007 | 05:04 PM
synner's Avatar
Default What year is my cable LS trans? I need a clutch!
Hey guys,
I need to order a new clutch for my cable trans but I dont want to order the wrong one. I have the trans pulled, and I counted 24 splines on the input shaft. All I "know" is that it was from an LS. I found an old clutch alignment tool that came with an old exedy clutch for a 99 Si, and it was to big for the pressure plate. All I have come up with as far as searching is that there are two different input shafts on cable B-series clutches...small (for 90-91), and big (92-93). I haven't found any mention of spline counts for B-series, only for d-series. Also, what shaft is on the B16 cable trans? I would like to order a clutch tonight. Thanks guys.
Old Aug 12, 2007 | 05:12 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
if the clutch alignment tool for 92+ b-series didn't work, then it's definitely a 90-91 tranny/clutch.
order a clutch for a 90-91 teg.
Old Aug 12, 2007 | 08:08 PM
Rd91SiB18ls's Avatar
Default Re: (full Circling)
24 spline is 90/91, I have both slightly used exedy,
I have a 91 s1 tranny in my car right now.
Order a 90/91 clutch kit.good luck
Modified by Rd91SiB18ls at 4:21 PM 8/13/2007
mycivicislower
18
May 9, 2009 07:10 AM
strawberry
Jan 11, 2008 02:34 PM
gtfour43
Jul 16, 2004 08:12 AM
allmotor.net
Apr 24, 2003 02:23 PM
REDBARON
Jan 21, 2002 09:09 AM
