my motor is dead!!!
Old Aug 12, 2007 | 03:29 PM
DA_JDM's Avatar
Default my motor is dead!!!
My engine builder re-adjust my valve last week and now my engine died yesterday at the track...can some bad valve adjustment cause this??? I dont have pictures and the head is gone with my engine builder to see what went wrong...i went 1st gear, 2,3 and at 7500rpm in 3rd the car lost power...i turn the ignition off and start it back and heard that trrrrrrrrr sound...timing was not touch, camshaft are ok, springs and retainer too, 3 pistons are still good but all the 4 valve seat needs to be redone, the block only have 4000km since the rebuilt i hope my builder arrange me something with the warranty Ill update pictures later on this week!!! Its a really sad story
Old Aug 12, 2007 | 09:03 PM
Hybrid96EK's Avatar
Default Re: my motor is dead!!! (DA_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">My engine builder re-adjust my valve last week and now my engine died yesterday at the track...can some bad valve adjustment cause this??? I dont have pictures and the head is gone with my engine builder to see what went wrong...i went 1st gear, 2,3 and at 7500rpm in 3rd the car lost power...i turn the ignition off and start it back and heard that trrrrrrrrr sound...timing was not touch, camshaft are ok, springs and retainer too, 3 pistons are still good but all the 4 valve seat needs to be redone, the block only have 4000km since the rebuilt i hope my builder arrange me something with the warranty Ill update pictures later on this week!!! Its a really sad story </TD></TR></TABLE>
Id say its POSSIBLE that adjusting the valves rediculously tight could cause interfearance issues... But it would be something that would become a problem the first time you hit Vtec or cracked into it. Without knowing a whole lot about the build, I couldn't tell you much more.
Old Aug 12, 2007 | 09:25 PM
Combustion Contraption's Avatar
If you ran at ZERO lash, chances are probably better that something got extra hot in that particular cylinder, and that was the cause of your issues. Unless youre running ridiculously tight P2V clearances, you should have more than .007-.009 of p2v.
Old Aug 13, 2007 | 08:50 AM
DA_JDM's Avatar
Default Re: my motor is dead!!! (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">
Id say its POSSIBLE that adjusting the valves rediculously tight could cause interfearance issues... But it would be something that would become a problem the first time you hit Vtec or cracked into it. Without knowing a whole lot about the build, I couldn't tell you much more.</TD></TR></TABLE>
The built made 215/135 on a mustang dyno
Port and polish ITR head
JUN 3 cams
Spoon sport adjustable cam gear
JUN spring+retainer
Ferrea competition plus valves
Wiseco 12:5:1 81.5mm pistons
Crower rods
ARP bolts all around
Spoon sport 2 layer headgasket
Old Aug 13, 2007 | 08:53 AM
DA_JDM's Avatar
Default Re: (Combustion Contraption)
He was suppose to adjust them cold at 007...maybe he made a mistake or something i really dont know...we wait 2 hours before adjust them so maybe it was not enough Anyway i will know what is gonna be the outcome from is part this week and at most the end of august...its strange that the timing was not touch and the belt was untouch
Old Aug 13, 2007 | 02:23 PM
DA_JDM's Avatar
Default Re: (DA_JDM)
All the exhaust valve went touch all the pistons...but it was only the valves on the #4 cylinder and the piston #4 that were all fucked up...and the lower part of the spark plug #4 was cut...
Modified by DA_JDM at 3:36 PM 8/13/2007
Old Aug 13, 2007 | 03:03 PM
kevinz's Avatar
one cyclinder got messed up??? sounds like your valve floated,,,
Old Aug 13, 2007 | 03:25 PM
DonF's Avatar
Default Re: (kevinz)
If your engine ran on 4 cylinders you had valve clearance. The differance between .002 and .007 should make no differance at 7500 RPM as you claimed. At 10,000 yes, 7500 No.
Old Aug 13, 2007 | 03:35 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinz &raquo;</TD></TR><TR><TD CLASS="quote">one cyclinder got messed up??? sounds like your valve floated,,, </TD></TR></TABLE>
Yeah one cylinder and one piston...but all the rest of the piston mess up the rest of the other cylinders and the other 3 pistons...all that on a 4000km rebuilt motor...only my engine builder touch the motor after it was in the car...he just adjust my valve last week-end Hope he come up with something to help me out...it wa snot a mishift and it was clearly not my fault!!!
Old Aug 13, 2007 | 03:40 PM
DonF's Avatar
Never is.
Old Aug 13, 2007 | 03:44 PM
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Never is.</TD></TR></TABLE>
Old Aug 13, 2007 | 03:56 PM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">All the exhaust valve went touch all the pistons...</TD></TR></TABLE>
nice engine building techniques
Old Aug 13, 2007 | 04:51 PM
kevinz's Avatar
Default Re: (Chris Tune)
Its hard to blame the builder when you are racing.
It is even possilbe for a piece off the throttle body or trash or anything to get sucked up the intake and lodge itself inside the head and cause the valve to stay open, this happens. Trust me, **** happens. Ever seen a pro AM car's engine blow on a dyno? 10k down the drain,R&D is m-fer.
Old Aug 13, 2007 | 06:00 PM
DA_JDM's Avatar
Its easy to blame the builder...i have put together all the best pieces and ive been reving stock b18c5 motor to 9k all day long for months and months since 2 years and no **** happen...this block was built to see some 10k action but i have my rev limiter set to 9200rpm...the motor was all good and boom 4 days after he re-adjust my valve the motor died...strange I hope he will help me out with the issue
Old Aug 13, 2007 | 06:26 PM
coneheadsracing's Avatar
What did you tune it with? Did you tune it all the way to 10k before you went racing with it? What octane were you running, the list goes on and on. Easy to blame the guy who put it together. Easily could be his fault, but parts fail, **** happens, welcome to racing.
Old Aug 13, 2007 | 08:16 PM
DA_JDM's Avatar
Default Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">What did you tune it with? Did you tune it all the way to 10k before you went racing with it? What octane were you running, the list goes on and on. Easy to blame the guy who put it together. Easily could be his fault, but parts fail, **** happens, welcome to racing. </TD></TR></TABLE>
The set-up was not tune to 10k but was making power up to 8900...fuel cut at 9200...never went at that mark...tuned on hondata s100 since the month of june, tuned and never used nothing else then 94octane...never had trouble with the engine before that day with lots of drag racing!!! Motor was strong...im just dissapointed that ive done my valve adjustement and after maybe 200km boom the engine blow A built like ive done should last a lot and a lot more then 4000km
Old Aug 13, 2007 | 09:02 PM
Rollo Lawson's Avatar
racing and blowing motors go hand in hand, sometimes. wlecome to the game.
Old Aug 13, 2007 | 11:25 PM
xynic's Avatar
I hate it when stuff like that happens..... Where can I find a new motor?
petty$rep
Nov 10, 2006 08:59 PM
RCautoworks
Aug 31, 2005 10:17 PM
Shift_Fast
Feb 19, 2005 11:24 AM
951dc5
Nov 18, 2004 06:56 PM
