Honda S2000 Honda S2000
how do you move the fuel line in the trunk out the way?
Old Aug 12, 2007 | 02:45 PM
IntegraLs94Cam's Avatar
Default how do you move the fuel line in the trunk out the way?
I am lowing me s2000 and finished the fronts easy, but alittle unsure what to do on the rears. How do you move the fuel line that is in the way of the driver side shocks?
I douno if i am retarted or something, but i unbolted the 3 bolts near the gas cap and the unbolted the bolt on the bracket, but how do i get the fuel line out of the way? i don't want to mess anything up. I think i may have to push it into the car, but dont want to try it till i hear from you guys.
Thanks ,
cameron!
Old Aug 12, 2007 | 04:45 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: how do you move the fuel line in the trunk out the way? (IntegraLs94Cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">I am lowing me s2000 and finished the fronts easy, but alittle unsure what to do on the rears. How do you move the fuel line that is in the way of the driver side shocks?
Thanks ,
cameron!</TD></TR></TABLE>
you dont need to remove the fuel lines at all... we just did my buddies... just use an extension and u can get to all the bolts... btw his car looks sick with the espeliers
Old Aug 13, 2007 | 08:12 AM
jdm j's Avatar
Default Re: how do you move the fuel line in the trunk out the way? (S2KILLA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">just use an extension and u can get to all the bolts...</TD></TR></TABLE>
Yeah, he is right...you don't need to remove the fuel line (piping), but I'd recommend removing the bolts so you can pull the line back a bit to give you more room to work with!
Old Aug 13, 2007 | 08:42 AM
red9s's Avatar
i just finished this yesterday, and yes, do what jdm j says
http://www.s2000turbo.com/inde...id=27
Old Aug 13, 2007 | 08:58 AM
S2KILLA's Avatar
Default Re: how do you move the fuel line in the trunk out the way? (jdm j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm j &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, he is right...you don't need to remove the fuel line (piping), but I'd recommend removing the bolts so you can pull the line back a bit to give you more room to work with! </TD></TR></TABLE>
ehhh be a man... u dont have to
just have a magnet on hand just in case the nut falls into the crevice under the lines...
Old Aug 13, 2007 | 09:37 AM
iloveADOBO's Avatar
remove the 3 8mm bolts near the gas tank ( open the gas lid - you'll see the bolts)
its pretty easy.
TEGMAN89
Honda S2000
Aug 21, 2017 09:47 PM
hoytheld
May 16, 2014 02:12 PM
JLefevers
Jan 1, 2008 09:20 PM
civickiller
Mar 27, 2004 06:43 PM
jaxle
19
Jun 27, 2003 03:59 PM
