Problem with LS/VTEC swap
Old Aug 12, 2007 | 12:24 PM
hatch b16a guy's Avatar
Default Problem with LS/VTEC swap
I have a 92 cx with a ls-vtec swap. I do the swap and drive it down the road it is throwing a 14 and 1. The car is running like straight dog **** and vtec engauges off and on and it will not go over 7 grand or else i think it would blow its brains out every where. Has anyone else had this problem if so what wtf do i do. Thanks
Old Aug 12, 2007 | 12:29 PM
Luserkid's Avatar
Default Re: Problem with LS/VTEC swap (hatch b16a guy)
Well fix your IAC problem (code 14) and o2 sensor (code 1) first. Also what ecu are you running, your going to need to get tuned if you want it running 100%
Old Aug 12, 2007 | 12:57 PM
Default Re: Problem with LS/VTEC swap (Luserkid)
Well i just got rid of the 14 by taking it off and cleaning the crap out of it so now it is only throwing a one but now it is not kicking over the vtec. I am running a chipped p72 which came out of another ls-vtec swap and ran like a champ. Another question i am running a del sol harness so the 02 plug is up by the head since the del sol has the 02 in the manifold mine is in the back on the muffler pipe so I splice into the 02 sensor its self and add wire should i have cut the plug on the harness and extended that instead of the o2 sensor its self thanks
GHOST2049
Jun 15, 2012 11:24 AM
akteamster
Dec 12, 2005 08:57 AM
articbluedc5
May 19, 2004 05:20 AM
