how much boost
Old Aug 12, 2007 | 10:47 AM
blackcrx16's Avatar
Default how much boost
how much boost can a typer r take before an explosion occurs? im thinking about boosting my type r
Old Aug 12, 2007 | 10:56 AM
JjuuN R's Avatar
83LBS...
Old Aug 12, 2007 | 11:00 AM
BG-Teg's Avatar
Default Re: (JjuuN R)
i heard of a guy around my area that had a stock ITR in a civic hatch amnd was at the track tryin to blow it up for the new motor going in, lets just say after multiple boost cranks he was running 28lbs and it didnt come close to poping
Old Aug 12, 2007 | 11:14 AM
carzntune's Avatar
Default Re: how much boost (blackcrx16)
It's not psi that is the limiting factor, it's moreso the power output and the tune. There are multiple 350-ish whp R engines running safely. My bone stock JDM engine Civic ran 385whp safely so that gives you an idea of what can be done with the right parts. Search around the forced induction section and you'll find alot more info.
Old Aug 12, 2007 | 11:34 AM
itr1244's Avatar
Default Re: how much boost (carzntune)
Zero.
n/a doesn't need any boost
Old Aug 12, 2007 | 01:22 PM
doood's Avatar
been there done that
Default Re: how much boost (itr1244)
you can blow it up at 200whp or 600whp
Old Aug 12, 2007 | 02:53 PM
machgo5go's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">Zero.
n/a doesn't need any boost</TD></TR></TABLE>
Go buy a scooby or evo instead.
Old Aug 12, 2007 | 03:02 PM
MOVE OVER's Avatar
Default Re: how much boost (machgo5go)
how many times does the same question need to be asked?
Search please.
Old Aug 12, 2007 | 03:34 PM
blackcrx16's Avatar
ok i ment to say with some 450cc injectors and a tune, how much boost can i run safely
Old Aug 12, 2007 | 04:43 PM
Doostur's Avatar
at 450cc and a really good tune you could run 10 pounds but there is always that chance. Me personally would run at 6-8 pounds TOPS. Dont risk it man just save your money and build it up.
Old Aug 12, 2007 | 05:17 PM
Casey's Avatar
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">at 450cc and a really good tune you could run 10 pounds but there is always that chance. Me personally would run at 6-8 pounds TOPS. Dont risk it man just save your money and build it up.</TD></TR></TABLE>
haha on 450s? youre smokin some goood stuff.
to the OP: i wouldnt boost it. if you havent looked into it enough to know whats safe, youre better off not doing it at all. PSI is not what limits the motor, its HP limited
Old Aug 12, 2007 | 06:53 PM
doood's Avatar
Default Re: (blackcrx16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcrx16 &raquo;</TD></TR><TR><TD CLASS="quote">ok i ment to say with some 450cc injectors and a tune, how much boost can i run safely</TD></TR></TABLE>
you're limited to 300-350whp with injectors that small
Old Aug 13, 2007 | 10:55 AM
wegotmorrison's Avatar
Default Re: (doood)
I wouldnt boost an R
Old Aug 13, 2007 | 11:06 AM
Dave_B's Avatar
Keep cranking it up and let us know where it pops.
Old Aug 13, 2007 | 11:07 AM
coolhandluke's Avatar
Default Re: (wegotmorrison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">to the OP: i wouldnt boost it. if you havent looked into it enough to know whats safe, youre better off not doing it at all....</TD></TR></TABLE>
Old Aug 14, 2007 | 08:42 AM
RedR's Avatar
Default Re: (coolhandluke)
Push whatever psi to reach your goals, keep them reasonable as its a stock motor, a lot of them are running 300-350 without issues, dont cheap out on the parts and specially on the tuning.
i´ve been running boost for 1 1/2 years without issues (so far )
Old Aug 14, 2007 | 10:22 AM
citrus3000psi's Avatar
Default Re: (RedR)
If you don't have the money to build up the motor and don't have the knowledge to put it together then don't do it.
Do some research. This does not mean ask stupid questions of "how much boost can a type r handle"
Go look up how forced induction works, how timing effects power, how to tune. Go download AEM and mess with the settings. You will relize that there are hundreds of options that you will not know. So go start learning.
rdeezy78
Aug 27, 2007 03:19 PM
clutch6racerone
May 29, 2007 11:17 AM
theblkrascal
Oct 27, 2005 06:48 AM
ras
May 3, 2005 09:14 AM
92-h23a1
Aug 7, 2003 08:40 AM
