d16a6 into 89 civic hatch
Old Aug 12, 2007 | 10:21 AM
raiden571's Avatar
Default d16a6 into 89 civic hatch
well. i have the motor in and im starting the wiring. all was good until i noticed i had a square plug on my old dizzy and a round one on the a6 dizzy. what the hell do i do? i was able to find the different dizzys online and compare, but is it possible to swap plugs? what am i suppose to do. all the mpfi-dpfi write ups dont really acknowledge this. when i tried hooking up just the si harness, the driver side plug does not fit. im lost and need tis car running so i can get to work. any help would be great
Old Aug 12, 2007 | 02:12 PM
janz3n's Avatar
Default Re: d16a6 into 89 civic hatch (raiden571)
its pretty simple actually. im sure at least one write up explains this.
take your old distributor squar plug off and put it on the new si distributor.. match up the wire colours plug it in. and you should have two extra wires that you had to ad to the mpfi swap and solder those together.
Old Aug 12, 2007 | 08:52 PM
raiden571's Avatar
thank you.
ninty1civic
Nov 11, 2009 11:33 PM
Supahatch
Oct 31, 2009 09:08 AM
thedudefromjerz
Feb 20, 2008 08:53 AM
UNDER PRESSURE
Oct 26, 2007 06:13 PM
turbo sol
Apr 28, 2003 11:08 AM
