Tranny Dilemas
Old Jun 12, 2002 | 10:54 AM
Alpha_GSR's Avatar
Default Tranny Dilemas
I have a fully built LS/Vtec putting out 205hp/150tq to the wheels.
Recently my tranny has been grinding into second and I'm not totally sure what I should do. My options are:
Buy used ITR tranny,
or Rebuild GSR tranny and add either ITR LSD or Quaife LSD.
What are some respectable prices I should pay for both setups and give your opinions. Keep in mind I don't know how to do my own labor. Also my car is my daily driver. Any help will be greatly appreciated.
Kong
Old Jun 12, 2002 | 11:09 AM
jdmcx's Avatar
Default Re: Tranny Dilemas (Alpha_GSR)
i have an lsvtec motor that consists of ctr pistons ls rods ls crank type r oil pump gsr head jg sprigs and valves and a slight clean up on the head
what do you think my hp is
any way i blew my gsr tranny on the track alot of wheel hop (Z10 RADIUS RODS ARE YOUR BEST FRIEND) i am looking for another trannny i would rebuild your gsr tranny and put the quaife lsd in it that way you could also do all your syncros and check the forks ect... if you buy a type r one you end up spending more money and you may still have to replace 3rd guear syncro
just a thought
ps what is your set up to get 205 hp 150 tq
Old Jun 12, 2002 | 11:11 AM
hybridreams's Avatar
Used ITR tranny: 700-1000 depending on mileage
Rebuild GSR: I dunno
ITR LSD: Check out eBay, there are a couple on there right now, brand new
Quaife LSD: Pretty much $800
Old Jun 12, 2002 | 11:28 AM
Alpha_GSR's Avatar
Default Re: Tranny Dilemas (hybridreams)
my setup is:
GSR portflow p&p head
port flow valve springs and retainers
Skunk2 Stage 1 cams w/ cam gears
Skunk2 IM
Comptech Icebox
Golden Eagle sleeved 2.0L
JE 12:1 84.5mm
Vtec oil pump and water pump
ARP head studs
Eagle Rods
CM lightweight FW and Stage 4 clutch
AEM fuel Rail w/ RC 310 injectors
Hondata Stage 2 tuned by Jeff at IB.
DC JDM 4-1 w/ carsound cat and stock muffler!! With AC and power steering.
Recently upgraded w/
Erick's Racing TB
JG Edelbrock header modified by IB
MSD wires, MSD 6A, and blaster coil
Right now I'm hoping for 215 to the wheels. Are my hopes realistic?
Old Jun 12, 2002 | 02:23 PM
builthatch's Avatar
MiG-21 superfan
the rebuild prices are impossible to conjecture until the required werk is documented...who knows, there are so many moving parts inside that thing...when you tear it down, besides the synchro(which i think comes in 2 gear sets from honda, $$$), you mite need shift fork(s), and some other parts like mainshaft bearings mite show some soon-to-be-fatal wear when you tear it down...the itr trans is a gamble, there should be a guarantee atleast for 1k miles or 3 months, to give you ample time to see that it werks as it should...
BEEYOND
Aug 4, 2010 11:01 PM
cotten_itr
Jul 10, 2007 08:48 AM
Paul*DC4
Jun 25, 2007 10:26 PM
racerjohn
Jul 17, 2006 12:55 PM
Teggy94
Oct 17, 2003 11:12 AM
