96 civic horn and cruise control HELP!
Old Aug 12, 2007 | 08:17 AM
Kyo Babic's Avatar
Default 96 civic horn and cruise control HELP!
Ok so i installed my momo steering wheel and hub on 96 civic, found which wires were what and relocated the cruise control as per the link bellow. the cruise control works great. but horn...well it works kinda too well lol,...its contantly on...i had to bend the contact tab back just to turn it off, its getting constant power to it, im a bit confused with it, is there a different way to wire the horn?
http://importnut.net/civicsteeringswap.htm
Modified by Kyo Babic at 1:13 PM 8/12/2007
Old Aug 12, 2007 | 12:15 PM
Kyo Babic's Avatar
Default Re: 96 civic horn and cruise control HELP! (Kyo Babic)
up ya go!
Old Aug 12, 2007 | 12:27 PM
sageuvagony's Avatar
I took my horns (Many fords use 2 horns) off my explorer and put them on my civic. When I connected it (It's 2 horns mounted on one bracket making it 1 unit), that thing made me JUMP like a ****. It stayed on, and with the shock of the friggin scare, I couldn't think straight in those few seconds. It left a ringing in my ears for a while. Imagine sitting on the floor comfy with your legs crossed, relaxed, cutting and splicing wires, and out of nowhere, HOOOOOOOOOOOOOOOOOOOOOOOONK! Those horns are LOUD when not sitting behind a bumper and right in front of your face For some reason civics (maybe all hondas) have the horn system operating in reverse (or they function in reverse).. like... the positive wire is constant, but the negative isn't. It's weird in a way. Whatever you do, make sure you didn't ground the horn to the frame.
Fords, their horns have 2 wires. One positive and one negative. Like any normal thing in a car, the ground is always connected/grounded, and the positive is connected to either a switch or button, and when activated, power is applied
I know for a FACT that you have your horn connected to a constant ground.
Modified by sageuvagony at 1:38 PM 8/12/2007
Old Aug 12, 2007 | 12:41 PM
Default Re: 96 civic horn and cruise control HELP! (sageuvagony)
I just re-read the post and I was explaining how the horn itself connects and not the button, but at least with that concept you know that something is reversed somehow or... blah.. I'll try to help in a sec. Have to take my sis to work right now.
BTW the site doesn't load.
Old Aug 12, 2007 | 12:47 PM
Kyo Babic's Avatar
yeah iam getting a shock when i touch the wire to contact, i have it wired the same way the guy has it in the pics in that link i posted, so im kinda wondering maybe the horn conections ar different from eg to ek?...cuz i have a ek, but the link is for eg....although my cruise works great.
Old Aug 13, 2007 | 09:12 AM
Kyo Babic's Avatar
everything works now...apparently i needed some sleep...working on your car with like 2hrs sleep makes for really easy stupid mistakes
Jtisawesome
Jun 21, 2012 05:05 PM
gnxpro24
Sep 24, 2010 02:00 PM
Sohc-it
Sep 14, 2010 07:47 PM
you69
Mar 13, 2003 10:35 AM
