13.5@110 mph WTF?
I took my car last nite at the track with 24.5x8.5x13 slicks and ran this horrible
time and I also preload the car due to its stock axles my car also makes good power it dynoed 446WHP and 288ftlbs. of torque come on now i should be at least in the 11's with this power and my mph is pretty damn low, what could be wrong with the car? and I also got a horrible 2.2 60'foot with slicks and R1 coilovers, could the slicks maybe too big for the car, could be the coilovers be crapped? Even with a horrible 60'foot the car should at least do decent time not a damn 13.5's and also I launched at 7500 rpm and the car boggs down on the launch, I know this is a pretty long and stupid question but i need help and inputs from the pros thanks.
Iv'e seen a lot of cars with a horrible 60'foot with less power than mines and same car and still did better than a 13.5's I don't think its the driving.
My eg w/drag radials, maybe 300hp,shifting at 6k,launching at 3500,ran 13.7 @107.Even with questionable driving you should be in the 12's with 400+ hp.
I ran 13.4 @ 109mph with 2.16 60ft ek 260whp with drag radials 195 50 15. Sounds pretty low since im only putting down 260 whp. Does my time sound right guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboosted »</TD></TR><TR><TD CLASS="quote">Im running a 4094r with 14lbs of boost of the wastegate spring you think i need a 2 step since is a big turbo? and I redline at 9200rpm.</TD></TR></TABLE>
you mean anti lag?
how is the powerband on that 4094?
you mean anti lag?
You're not using any type of launch control? Thats a good reason as to why your 60' is no good. How are you launching since you're not using a 2-step? Just holding the throttle at a certain rpm? Maybe you have a boost leak issue when you are racing, are you sure you are making 14lbs when you are racing? You should check your logs and see how much boost your were at.
