will B16 trans syncros work on GSR trans
Old Aug 11, 2007 | 10:15 PM
vtec4max's Avatar
Default will B16 trans syncros work on GSR trans
well, I have a LS hydro trans and I'm thinking about swapping in GSR 3rd and 4th gear. a set of B16 syncros are readily available for me at a reasonable price and thinking about buying them. will this work. Thanks in Advance!!!!!
Old Aug 11, 2007 | 11:43 PM
F20Cteg's Avatar
Default Re: will B16 trans syncros work on GSR trans (vtec4max)
Nope, 3rd and 4th GSR/LS synchros are smaller than the B16/R ones.
Old Aug 12, 2007 | 08:17 AM
vtec4max's Avatar
Default Re: will B16 trans syncros work on GSR trans (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">
I thought so too. Thanks again
Old Aug 13, 2007 | 05:41 PM
frostyrb's Avatar
Yeah but 1/2 & 5/R syncros are the same between gsr & b16.
Old Aug 13, 2007 | 07:46 PM
MikeSarr_GSR's Avatar
what difference in size are you referring to?
you should be able to put B16 synchros in. the hydro trannys should have the same
shaft diameters. when I had my b16 and gsr trannys apart before I hybridized
my gsr tranny by adding b16 3,4,5th gears to it - I compared all the parts and
the synchros were the same. I used the gsr synchros since they were fresher,
the tranny has 16K on it now since adding the gears and lsd.
Old Aug 13, 2007 | 08:12 PM
F20Cteg's Avatar
Default Re: will B16 trans syncros work on GSR trans (frostyrb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostyrb &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but 1/2 & 5/R syncros are the same between gsr & b16.</TD></TR></TABLE>
Yes that is correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">
You CANNOT put B16/R synchros with GSR/LS sliders/gears. The B16/R synchros are larger in diameter. The shaft size is irrelevant.
When you made a hybrid tranny you transferred over the gears and synchros together or you didn't have a B16 tranny.
Old Aug 13, 2007 | 08:39 PM
F20Cteg's Avatar
I took some pics so you all can see the differences. As you can see there is almost a 7mm difference in diameter.
First is a B16 3/4 set:
Second is a GSR 3/4 set:
Old Aug 14, 2007 | 05:23 PM
vtec4max's Avatar
understood!!! Thanks
slostjoe
Oct 12, 2010 02:19 PM
1junkycivic
May 9, 2008 09:25 AM
lubmyinteg
Aug 28, 2007 10:59 PM
smokerz212
19
May 6, 2006 06:10 PM
dasistheone
Nov 10, 2005 08:55 PM
