Looking for big SOHC Dyno Numbers and Setups
Old Aug 11, 2007 | 09:20 PM
VTECJUN's Avatar
Default Looking for big SOHC Dyno Numbers and Setups
Just curious what people are doing for SOHC VTEC builds. I have a customer that wants to do a big build on an D16z6 so I am just looking to see what has been done, for example what cranks are interchangeable for more stroke, and what OEM pistons will raise compression with stock crank. I have always been a B Series guy just never messed with D Series parts. Thanks in advance.
Matt
Old Aug 12, 2007 | 05:40 AM
DougNuts's Avatar
I think the D16Z6 motor has many options.
Here are some factory options.
http://heeltoeauto.com/httech/...87887
Old Aug 15, 2007 | 04:36 AM
spun Vtec's Avatar
Default Re: (DougNuts)
My setup is in my sig.
Old Aug 15, 2007 | 05:54 AM
b19coupe's Avatar
Default Re: Looking for big SOHC Dyno Numbers and Setups (VTECJUN)
Ask these guys:
http://www.d-series.org/
Old Aug 15, 2007 | 08:50 AM
lohatch's Avatar
also i think the latest honda tuning magazine has an article on putting the d17 crankshaft into the d16 to pick up some stroke
Old Aug 15, 2007 | 11:02 AM
Aquafina's Avatar
Default Re: Looking for big SOHC Dyno Numbers and Setups (lohatch)
Yep. Just sleeve it and 78mm bore. If you really to want to go at it, throw a D17 crank in as well.
Old Aug 15, 2007 | 07:08 PM
BIGTUNA's Avatar
Default Re: Looking for big SOHC Dyno Numbers and Setups (Aquafina)
Well heres what a allmotor nonvtec sohc sounds like with a full aray of bisimoto parts. There is alot more potential in the nonvtec sohc's than the vtec sohc's. I have had both, raced both, and built both and the nonvtec setups have alot more bang for your buck. A good choice for any entry level sohc is the P-29 pistons, they are higher compression and can be had for 150ish off of ebay with rings.
Setup
Bisimoto Custom Pistons 76mm
Pauter rods
KMS Blockgaurd
Cometic HG
PnP Head
Bisimoto Valvesprings
Bisimoto Ti Retainers
Bisimoto Level 3 hardweld cam
Blox ported Intake Manifold
Type R Throttle Body
Tec 2 Standalone EMS
and hopefullys soon a Bisimoto Header
and a whole lot of other goodies.
Old Aug 18, 2007 | 05:22 AM
Bisimoto's Avatar
Matt, shame on you...you know who to call...see you soon!
Old Aug 18, 2007 | 05:44 AM
d15Beta's Avatar
heres a motor i did a few months back..
http://www.d-series.org/forums...90980
a little more fine tuning it wud put out more..
due to time constraints and other stuff, we were happy with the result!
buildit
Nov 20, 2008 07:45 AM
builthatch
16
Apr 12, 2005 05:25 PM
DemostheneZ
19
Aug 19, 2004 11:27 AM
del_sol
Feb 13, 2003 06:47 AM
alphaquake
28
Jun 10, 2002 12:19 PM
