which air conditioning belts for b-series swap into ek?
Old Aug 11, 2007 | 04:58 PM
1zach4's Avatar
Default which air conditioning belts for b-series swap into ek?
Ok well I ran into some problems getting my b18b swapped into my 99 ex...I purchased what was supposed to be the proper a/c bracket for my swap, but the guy sold me a p30 bracket (99-00 si bracket) so it won't bolt up to the d-series a/c compressor, so now i'm going to buy the pj7 bracket (crv bracket)
Which a/c belts do I need in order to run the crv a/c bracket and d-series compressor on my b18b1 swap in my 99 ex?
Old Aug 12, 2007 | 01:09 PM
1zach4's Avatar
Default Re: which air conditioning belts for b-series swap into ek? (1zach4)
bump
Old Aug 12, 2007 | 01:23 PM
SMOOTHN's Avatar
you can use either the LS or crv belt with the swap...
Old Aug 24, 2007 | 07:56 PM
marshun's Avatar
Default Re: (SMOOTHN)
that or you can simply measure up what you want and go to the store (checkers or whatever) and tell them what you need. make sure you remember how many ribs it has also.
Old Jul 25, 2010 | 02:51 PM
underdog1's Avatar
ok this is what u need get the a/c belt for ur civic ,ans use the same tensor too.you should be good .
Old Jul 25, 2010 | 03:53 PM
97civicdx's Avatar
Your supposed to get the Del Sol V-tec P-54 ac bracket or the CRV ac bracket.
jeffhoe
Mar 1, 2013 04:32 PM
SyDuck
Jul 16, 2006 12:34 AM
Turbo_Mike
Jun 25, 2006 12:19 PM
wizzards581
Mar 8, 2004 09:27 PM
ef ect
Jan 22, 2003 07:09 PM
