Gsr crankshaft...ls rods...
Old Aug 11, 2007 | 02:11 PM
swapped95's Avatar
Default Gsr crankshaft...ls rods...
Im building as ls vtec and ran into problems...it starts out, i bought a b18a1 that had spun rod bearings so the crank was trashed. i found a gsr crank thinking i could use my eagle h beams i bought for the ls on the gsr crank. it doesnt fit the crank...so basically what im asking is the gsr crank the same stroke as the ls crank, can i just get some gsr rods and still have the stroke as the ls?????????
searched and didnt find exactlly what i was looking for...thanks in advance and if you try to burn me...expletive you!!!
Old Aug 11, 2007 | 03:15 PM
swapped95's Avatar
anyone in texas with ls crank??? or close to texas
Old Aug 13, 2007 | 04:05 PM
funk.regulator's Avatar
Default Re: (swapped95)
ls has a bit more stroke than the gsr.
Old Aug 14, 2007 | 11:43 PM
F20Cteg's Avatar
Default Re: (funk.regulator)
No. LS rods are not compatible with a GSR crank and the reverse as well. The LS big end is wider.
Also the GSR rods are longer. LS crank has a longer stroke like Funk said.
Old Aug 18, 2007 | 06:51 PM
RyanA's Avatar
Default Re: (F20Cteg)
If your GSR crank is in good shape, I'd swap it to you for a good LS crank.
swapped95
Aug 12, 2007 01:47 PM
swapped95
Aug 11, 2007 03:14 PM
jdmsijdm
Dec 19, 2004 10:53 AM
spettinger
Feb 12, 2003 03:10 PM
