Need quick help
you will need a a/c compressor that will allow the d-series compressor to bolt the b18.
lucky for us honda has already did the math for us.
part # 38930-P7J-000 (cr-v)
part # 38930-P54-000 (94-95 del sol)
the cr-v bracket is the exact same as the del sol bracket, but cheaper. as for the del sol bracket, for some reason you can't order the cr-v one, you will need to specify the 94-95 del sol bracket. the 96-97 bracket uses the same as any other b-series motor would.
but with me providing you the part #, you should be fine!
roc
Feb 29, 2004 06:01 AM
