'94 civic rattle
Old Aug 11, 2007 | 05:42 AM
wombosi's Avatar
Default '94 civic rattle
i'm posting a new thread because it seems like they get backlogged very quickly and people stop seeing them.
annoying rattle coming from a '94 civic dx sedan. near the muffler, but sounds like something metallic vibrating/rattling inside the body panel maybe.
before i jump in the trunk and have my girlfriend drive to try to find the source of the noise i thought i'd ask you guys what you think.
i put a new m uffler on it a few weeks ago, did a nice job. no leaks, nothing loose, muffler is not touching anything that it could rattle against.
is this a common thing for civics?
thanks.
Old Aug 11, 2007 | 06:54 AM
ShortyzKustomz's Avatar
Check your hangers. I had a rubber hangewr break at the resonator on my catback and it would make a horrible rattle at idle/ stop lights / anytime the a/c kicked on or off, etc. A $3 carquest OEM rubber hanger fixed it
Old Aug 11, 2007 | 06:56 AM
wombosi's Avatar
Default Re: (ShortyzKustomz)
thanks man.
do you mean the hangers at the end of the muffler?t he sound is definitely coming from the rear right of the car somewhere.
are there more rubber hangers down the piping?
good idea.
if it's not that, could it be some sort of rod rattling around in the trunk, or in the back right quarter panel?
thanks again.
Old Aug 14, 2007 | 12:30 PM
Mine was the rubber hanger about midway back on the car, right by the resonator, I was causing it to rattle near the back, Took 2 weeks to find someone with the right floor jack and some 2x4s to drive up on to get the jack under it. And finally got it replaced, problem solved!
Old Aug 14, 2007 | 12:36 PM
dizzzane's Avatar
Default Re: (wombosi)
Try also checking in between the cat and the heatshield on the top side, many times a small pebble will get in there and rattle around without coming out. Let us know what you find bro.
Old Aug 15, 2007 | 03:15 PM
Budget Racer's Avatar
Default Re: (MilanoRed_dc2)
Mine rattled against the bumper. I just pushed down on it away from the bumper several times. Eventually I pulled it down enough and the noise never came back.
Good luck
Old Aug 15, 2007 | 03:23 PM
brooksto's Avatar
Default Re: '94 civic rattle (wombosi)
what muffler did you put on
Old Aug 15, 2007 | 03:29 PM
wombosi's Avatar
put on a NAPA economy mufler, brand new. mounted it to the rubber mounts, new gasket and spring bolt kit. did a great job.
Old Aug 15, 2007 | 03:33 PM
wombosi's Avatar
Default Re: '94 civic rattle (brooksto)
in other news, fixed my girlfriend's brakes, front and back. got rid of the clicking noise. car stops on a dime.
Old Aug 15, 2007 | 03:42 PM
JKov240's Avatar
Perhaps a heat shield underneath the car that's hitting the exhaust?
Old Aug 15, 2007 | 03:45 PM
Gary.'s Avatar
I'd put cash on it being the hangers/heatshield too.
Best o luck.
Old Aug 15, 2007 | 03:59 PM
wombosi's Avatar
where's the heatshield?
honestly, it sounds like it's coming either from the muffler somewhere, or up in the body panel somewhere.
when you say it's the hangers, meaning one is missing somewhere?
if i can get this to go away i'll be a very happy man.
so what about the heat shield? just bang it out of the way? what about cranking the exhaust down with a coat hanger?
Old Aug 15, 2007 | 04:26 PM
JKov240's Avatar
Heat shields are on the bottom of your car between the car itself and the exhaust...you can either bang them out of the way or remove them completely (I wouldn't think removing them would hurt anything).
Old Aug 16, 2007 | 03:42 PM
Default Re: (JKov240)
Yeah I removed my heatshield. It's no big deal just dont go driving in tall grass unless you want to have a fire party.
I bet your shizz is vibrating on you bumper, or chassis.
Like I said try lightly stretching it away or down from all contact areas.
Old Aug 16, 2007 | 04:39 PM
Like I said check hangers. I never noticed how bad my whole sytem moved with just one broken ruuber hanger, I had it on a lift the other day and the whole exhuast system was moving because of that center hanger broken, the rattle was from the passenger rear side, but the hanger in the middle was the problem
Easton1215
Apr 26, 2015 06:34 PM
wagon94
Feb 16, 2010 09:45 PM
shadyimpala
Honda Civic (2006 - 2015)
13
Jun 7, 2008 01:46 PM
wombosi
Aug 10, 2007 01:32 PM
