who can CNC a custom shop press die?
Old Aug 10, 2007 | 05:56 PM
ROTARY's Avatar
Default who can CNC a custom shop press die?
i need a die made to shape tubing with my shop press, anyone that does CNC machining please post here or send me a pm, thanks.
Old Aug 10, 2007 | 06:34 PM
Laserjock's Avatar
Default Re: who can CNC a custom shop press die? (ROTARY)
A die like what I visualize you need does not require a CNC and can be run inexpensively on a lathe.
Im not trying to sound smartass-like.
Old Aug 10, 2007 | 07:28 PM
ROTARY's Avatar
Default Re: who can CNC a custom shop press die? (Laserjock)
the shape is rectangular and tapered.
i didn't take it as a smart-*** comment , i should have mentioned the shape in my first post.
Old Aug 10, 2007 | 08:18 PM
Race Egr's Avatar
Just curious what are you using it for? collectors id guess?
Old Aug 10, 2007 | 08:25 PM
ROTARY's Avatar
Default Re: who can CNC a custom shop press die? (NaPiEr)
yup, t4 divided.
Old Aug 10, 2007 | 11:46 PM
locash's Avatar
If you have a print, drop me a line..
Old Aug 11, 2007 | 05:46 AM
weiRtech's Avatar
OG Fabricator
yeah, a cad file would definitely be a good start. or atleast a sketch.
Old Aug 11, 2007 | 05:18 PM
ROTARY's Avatar
my cad drawing skills are limited but ill give it a shot and post a screen-shot and here.
Old Aug 15, 2007 | 10:03 AM
levelzero's Avatar
Default Re: (ROTARY)
Waiting for a drawing or a very accurate description
Old Aug 16, 2007 | 07:51 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY &raquo;</TD></TR><TR><TD CLASS="quote">the shape is rectangular and tapered.
i didn't take it as a smart-*** comment , i should have mentioned the shape in my first post.</TD></TR></TABLE>
Am I assuming you're trying to neck the pipe down? You won't really be able to add a taper to any pipe with a shop press simply with a tapered die - it will crush the pipe out and pinch it at the tapered end. The typical way to do is is the spin the pipe on a special lathe, then hammer it down gradually with a special die thats internal and external. Of course this assumes you'll use it as I'm thinking, so no offense intended
Old Aug 16, 2007 | 08:51 PM
ROTARY's Avatar
I'm not trying to taper the pipe just the die.
Old Aug 19, 2007 | 10:34 PM
xci_ed6's Avatar
random idea on a way to flare the pipe to match the flange.
basically the wedge block bolts to the flange. the die is slightly under size of the flange hole when completely expanded, and is machined small enough to fit inside the pipe completely collapsed. a couple bolts into each die block go through guide slots in the wedge block. then the wedge, which is tapered to match the die blocks, is bolted loosely to the wedge block with a large bolt. cherry the pipe, slip the flange assembly on the end, and hit it with an impact. should be able to stretch the pipe to match the flange.
any one think it will work? There is definitely an easier way, but I can't think of it right now.
Old Aug 20, 2007 | 07:04 AM
.RTErnie's Avatar
Default Re: (xci_ed6)
I assume you want something like this... (ms paint ftw)
Old Aug 20, 2007 | 03:47 PM
ROTARY's Avatar
you got it earnie
i cant get the program to taper anymore than 92 degrees with the rounded corners but like you said the top needs to be just a bit smaller than the schedule 10 I.D.
Old Aug 30, 2007 | 10:11 PM
Rosko's Avatar
is this what you are after?
Old Aug 31, 2007 | 07:07 AM
ROTARY's Avatar
Rosko - thanks for helping, the shape im looking for is like your top picture but the top the same shape as the bottom and just a bit smaller than 2" measured diagonally.
i think that keeping the rectangular shape from the start would require less pressure since the corners take up less surface area then the circular shape.
Old Aug 31, 2007 | 10:02 AM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY &raquo;</TD></TR><TR><TD CLASS="quote">Rosko - thanks for helping, the shape im looking for is like your top picture but the top the same shape as the bottom and just a bit smaller than 2" measured diagonally.
i think that keeping the rectangular shape from the start would require less pressure since the corners take up less surface area then the circular shape.</TD></TR></TABLE>
what do the dimensions of the flange side need to be? how tall does the punch need to be?
Jose-aka-Pedro
Mar 21, 2007 09:22 AM
A.E Motoring
Mar 5, 2005 10:34 PM
crxhf19
Feb 17, 2005 09:47 PM
gribbs
Feb 25, 2004 06:06 PM
Dropped
Oct 9, 2001 02:46 PM
