Mid-Atlantic (Sales) VA, DC, and MD
Evans Tuning CRX Part Out
Old Aug 10, 2007 | 08:56 AM
Andrea's Avatar
Default Evans Tuning CRX Part Out
Turbo kit: Completely custom turbo kit based on Inline Pro T4 SS exhaust manifold. Manifold has been machined for the Tial 60mm wastegate and T4 outlet. Stainless wastegate tube welded to manifold for Tial 60mm wg. Kit includes Inline pro manifold, GT4294R 1.28a/r housing (exhaust housing high temp coated, compressor outlet modified for standard 3" coupler), coolant lines, oil lines, Tial 60mm wastegate, custom 2.5" stainless dumptube, custom 4" vband stainless downpipe (comes with both vband clamps, flex pipe, and a single o2 bung welded), custom Garrett 18 x 12 x 3.5 core with custom end tanks by Full Race, custom dual backdoor aluminum charge pipes (2.5" off turbo and 3" off intercooler to throttle body), Tial 50mm BOV, all silicone couplers and T-bolt clamps included. The 60mm wastegate will hold as low as 5lbs of boost off wastegate spring with zero boost creep all the way to 10K rpm. This is the most complete SFWD kit you will find at a great price. The turbo and wastegate have 12 passes on them. Everything else has half a season. Meticulously maintained, in excellent condition. This kit made just over 900whp on our Dynapack dyno on 45psi. The car went 9.91 @ 159.4mph. The car has gone 125mph in the 1/8th mile with this turbo kit. With dialing the car in more, this kit was capable of running consistent 9.5-9.6. SOLD.
Competition Clutch B-series twin disk: Used for half a season (approx. 40 passes). Discs have a ton of material left on them. No problems whatsoever with this clutch. Held 900whp with zero issues. SOLD
MSD boost controller: Works extremely well. Allows for laptop programming and datalogging. $250.00
Edlebrock 8 injector intake manifold: Used, but in excellent condition. Port matched to 72mm throttle body. Includes secondary fuel rail; however, secondary fuel injector holes can be plugged and manifold can be run as just a standard 4 injector manifold. Will include all fittings and barb connectors. Does not include injectors or primary fuel rail. For a b16/b18c5 head. SOLD
BDL 72mm throttle body: In excellent condition. Comes with TPS sensor. SOLD.
RC 750cc injectors: Both sets are low impedance and will require a resistor box if being used on a 92+ Honda. One set is meant for a Bosch style fuel rail (drop in for K-series). Other set is meant for standard Honda rail. $225.00 each set of 4.
FAST XFI EMS: Includes FAST Xfi EMS box with wideband o2, terminated harness, fuel and oil pressure transducers, 5 bar map sensor, coolant temp sensor, intake air temp sensor, remote datalogger box. Will also come with modified OEM Honda distributor to work with FAST. This is a turn key FAST system, no additional parts will need to be purchased. Is a plug and play system for a b-series Honda. You will need some kind of ignition system with this, such as an MSD. If purchased new, this EMS would run you close to $2800.00 for all of these parts, if not more and would not include the distributor, premade specific harness, and additional sensors. Asking $2000.00.
4" Stainless Vband custom exhaust for EF/CRX chassis: Comes with a Burns muffler. Muffler alone was well over 300.00. Fit and finish on the exhaust is perfect. Could possibly fit EG if exhaust was lengthened. Not another 4" exhaust this nice anywhere! $600.00
Pics of everything will be posted this evening.
Prices are firm and do not include shipping. Everything is in 100% working condition. Do not send me PMs asking if the parts work. We do not sell parts that are broken. Those PMs will not be answered. Also, do not send PMs asking why I'm selling everything. They will not be answered either.
Modified by Andrea at 2:38 PM 8/28/2007
Old Aug 11, 2007 | 04:42 AM
Andrea's Avatar
Default Re: Evans Tuning CRX Part Out (Andrea)
Pics are up.
Old Aug 11, 2007 | 01:02 PM
md23vtec's Avatar
Bump for good seller and kick *** setup .
Old Aug 12, 2007 | 04:38 AM
Andrea's Avatar
Default Re: Evans Tuning CRX Part Out (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">Bump for good seller and kick *** setup . </TD></TR></TABLE>
Thanks.
Old Aug 12, 2007 | 05:47 AM
11secEk's Avatar
Awesome setup!! i saw it inperson, good luck with the sale! cheap as hell!
Old Aug 13, 2007 | 04:28 AM
Andrea's Avatar
Default Re: Evans Tuning CRX Part Out (11secEk)
Exhaust added.
Old Aug 13, 2007 | 09:51 AM
Andrea's Avatar
Turbo kit is tentatively sold.
Old Aug 13, 2007 | 02:19 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
ill buy the throttle body
Old Aug 13, 2007 | 04:21 PM
Andrea's Avatar
Default Re: Evans Tuning CRX Part Out (1QwIkEf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote">ill buy the throttle body</TD></TR></TABLE>
It's still available.
Old Aug 13, 2007 | 07:57 PM
1QwIkEf's Avatar
pm me the paypal info.. i got the waste gate elbow off you a few weeks ago
Old Aug 14, 2007 | 04:58 AM
Andrea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote">pm me the paypal info.. i got the waste gate elbow off you a few weeks ago </TD></TR></TABLE>
Pm'd.
Old Aug 15, 2007 | 05:50 AM
Andrea's Avatar
Up.
Old Aug 15, 2007 | 04:27 PM
Andrea's Avatar
Old Aug 16, 2007 | 08:21 PM
Andrea's Avatar
Old Aug 22, 2007 | 06:34 AM
Andrea's Avatar
Old Aug 23, 2007 | 06:40 AM
Andrea's Avatar
Up again.
Old Aug 28, 2007 | 10:39 AM
Andrea's Avatar
Clutch is sold.
Old Aug 29, 2007 | 04:57 AM
Andrea's Avatar
Old Sep 11, 2007 | 06:35 AM
Andrea's Avatar
94delsol-b16a
Apr 23, 2012 08:39 AM
Andrea
Northeast (Sales)
20
Sep 11, 2007 06:34 AM
Andrea
Aug 29, 2007 04:43 AM
yusoslo
Apr 26, 2004 07:37 AM
bigTom
Jul 19, 2001 05:44 PM
