Rear sway bar removal
Last night I was trying to remove the rear sway bar so I can install the new one this morning. The problem is that I couldn't remove the bolts at each end of the sway bar. I can put a wrench on the nut side, but the bolt side is covered in a rubber boot and a linkage piece. When I turn the nut the whole bolt moves with it so I can never get it off. I was wondering if I'm supposed to somehow remove the endlink on the bolt side, so I can put something on the bolt too.
Just happened to go by dealership today for my passenger window problem, and the service guy went "well, you'll probably have to cut the bolt off and end up with a new link and bolt." I was gonna say the instruction I got just says remove the bolts, doesn't say anything about breaking the bolt. But from the look of him I'm pretty sure he have yet to work on it himself.
So what's up with it? Anyone who have other than stock sway bar can let me in the details?
So how do you remove the endlink covering the top of the bolt side? Just use screwdriver and prey it off? It's pretty snug, I don't want to break unless someone says that is how it's supposed to be done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR »</TD></TR><TR><TD CLASS="quote">REMEMBER the suspesnion should be under load when doin this
you can also use vice grips which i thought was easier to hold the nut that spins. i think its much easier that way.
try to find someone that has those ramps that you drive up on, i have em and the worked great
IDK what the consequences are, i just told you how to load your suspension. As mentioned above ramps. **** go pull into a driveway. If i had to guess tho i would say that not loading it you aren't going to be able to line the holes up. One side at a time may work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael Bolton »</TD></TR><TR><TD CLASS="quote">you can also use vice grips which i thought was easier to hold the nut that spins. i think its much easier that way.
try to find someone that has those ramps that you drive up on, i have em and the worked great</TD></TR></TABLE>
What Michael said. You can pick up a pair of ramps for about 40 bucks at Pepboys. Makes it easy to get under the car for these types of jobs, as well as makes it easy to clean under the car.
Ok, I have it installed. New question though, is it normal to hear poping sound while driving right after the install? I drove like 100+ miles yesterday and it was poping at the very start, but by the end of the trip, it was gone.
Glad to hear it, I dunno why so many people had problems with this, i did mine alone, and had the car on jackstands, wasnt a hard install at all. At first I thought I had the wrong part but that was my own idiocy.
96Formula6spd
Jun 9, 2011 05:13 PM
JEM MotorSports
Sep 4, 2006 02:48 AM
mixmastabob
Jan 6, 2004 09:51 PM
